07-04-2021, 03:37 PM | #1 |
Retorqing head
I’ve been advised to retorqing the head bolts on my 31 CCPU. What is the recommended torque and procedure?
07-04-2021, 03:46 PM | #2 |
Re: Retorqing head
I use this even though I do not have a Brumfield head but a different high compression head.
http://www.fordgarage.com/pages/brum...structions.htm What kind of head do you have and what is thr condition of your engine?
"The more things change, the more they stay the same." |
07-04-2021, 03:47 PM | #3 |
Re: Retorqing head
https://www.mafca.com/images/Cylinde...Tightening.pdf
This one says 50, but most folks do 55. But this will show you the sequence. |
07-04-2021, 08:33 PM | #4 |
Re: Retorqing head
I did the following and it seems to have worked: Initial torque to 55 ft-lbs on installation of head (in 10 ft-lb increments). Warm up engine then cool overnight. Re torque to 55 ft-lbs. Drive for a week or 100 miles. Cool overnight then re torque to 55 ft-lbs. Drive for another 500 miles or a month, cool and re torque. Re toque cold engine every 6 months. Loosening before re torquing makes sense but do one nut at a time. I used the copper anti seize on the nuts. Lubrication like the anti seize will mean that the tension on the studs will be greater than if assembled dry.
07-05-2021, 12:23 AM | #5 |
Re: Retorqing head
Just take your time and do it right. |
