Old 10-29-2019, 12:25 PM   #1
ford31
ford31's Avatar
Default radiator question
how far should radiator be from water pump shaft
ford31 is offline   Reply With Quote
Old 10-29-2019, 05:11 PM   #2
rocket1
Default Re: radiator question
As long as the fan clears the radiator your good,off hand it is probably several inches.
rocket1 is offline   Reply With Quote
Old 10-30-2019, 09:30 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
The position of the radiator is adjustable, and there are variations in the core thickness of reproduction radiators, so the clearance to the pump shaft will be a range of dimensions. I just measured the clearance on my 1931 Victoria which has a Walker radiator, and it has 0.75".
Bob Bidonde
Old 10-30-2019, 06:30 PM   #4
NZ28ModelA
NZ28ModelA's Avatar
I'm guessing, but i presume you don't have much choice as the radiator supports dictate how wide the bonnet gap will be???
NZ28ModelA is offline   Reply With Quote
Old 10-31-2019, 04:00 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
1" on my 1928 with solid motor mount and original pump and radiator.
Old 10-31-2019, 11:48 AM   #6
ford31
ford31's Avatar
thanks its going on my 28 doodlebug couldnt find good original have 2 both leak 1 quite abit other just a little bought a new aluminum will be here tomorrow
Old 10-31-2019, 04:31 PM   #7
woofa.express
woofa.express's Avatar
my new radiator cracked below the return pipe. I have the new type engine mounts, float a motor and they allow more movement and I reckon that allowed the engine to move forward just a smidgeon when the motor car accelerated. Thus a small movement. Well that's the most probable reason.
Give a margin.
And those mounts are great. No more tingling hands.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 11-03-2019, 08:29 PM   #8
Boss0144
What aluminum radiator did you choose?
My radiator is leaking when my truck is warm. I'm looking for a replacement.
Thanks!
Boss0144 is offline   Reply With Quote
