Old 11-10-2020, 02:12 PM   #1
Mike Barrett
Default clutch problem
Problem 2 with my Model A, When purchased clutch pedal went about 3/4 way down before engaging but seemed to work well. While getting car ready to be safety checked I thought why not adjust the pedal. Removed pin and turned clevis out about 7 or 8 turns, reinstalled pin. Clutch pedal seemed better but clutch will not disengage . Have tried with clevis in several different positions, same result, clutch will not disengage. My thinking is that clutch was worn and when we disconnected it something fell out of place inside ? Again any help will be appreciated.
Mike Barrett is offline   Reply With Quote
Old 11-10-2020, 02:40 PM   #2
johnbuckley
johnbuckley's Avatar
Default Re: clutch problem
Can it still work if you go back to the original position?
Old 11-10-2020, 03:00 PM   #3
Bob C
how much free play to you have??
Old 11-10-2020, 03:45 PM   #4
Mike Barrett
No, tried every position
Old 11-10-2020, 03:45 PM   #5
Mike Barrett
doesn't matter where I set it, pedal goes to floor
Old 11-10-2020, 04:35 PM   #6
Ak Sourdough
Ak Sourdough's Avatar
Look for a cracked/broken linkage arm on the throwout bearing shaft that comes out of the bell housing.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer.
Ak Sourdough is offline   Reply With Quote
Old 11-10-2020, 04:37 PM   #7
Ak Sourdough
The broken ones I've seen cracked across the sleeve that goes over the shaft.
Old 11-10-2020, 08:08 PM   #8
1955cj5
1955cj5's Avatar
Here are a couple pictures...
A broken/repaired arm and it's replacement.
The second picture is it's location.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 11-11-2020, 04:39 AM   #9
johnbuckley
If the soluttion is not on any of the above posts next thing is remove the inspection plate and have a look-see whilst pushing the clutch pedal
Old 11-11-2020, 02:30 PM   #10
Mike Barrett
tried again today, found a position that allowed clutch to operate (not happy with the pedal though, goes down way too far) clutch worked while car was on stands. Put car down on floor, car won' t move. As to post #9 I have taken the inspection plate off. Everything seems to be working. Is there an adjustment in this spot ?
Old 11-11-2020, 03:03 PM   #11
Bob C
You've never answered the question of how much free play you have.
Old 11-11-2020, 04:13 PM   #12
J Franklin
J Franklin's Avatar
If the car won't move with the pedal released you have a clutch that will not engage. Check the free play, or answer Bob's question and we can think some more.
Old 11-11-2020, 04:21 PM   #13
Mike Barrett
If freeplay is what I think it is (loose pedal from top until you feel pressure) I have 4".
Old 11-11-2020, 04:25 PM   #14
J Franklin
J Franklin's Avatar
Trim that to 1" But it does sound like you have a bad clutch.
Old 11-11-2020, 06:02 PM   #15
Mike Barrett
I am starting to think so
Old 11-11-2020, 07:09 PM   #16
Mulletwagon
Mulletwagon's Avatar
If no luck with one inch of free play the problem is more challenging. Your description sounds more like a clutch disk worn too thin; a condition that normally occurs gradually. Another condition which causes no engagement is much less than zero free play which precludes the pressure plate/flywheel from contacting the disk. Interesting caper - tell us how it ends.
Mulletwagon is offline   Reply With Quote
Old 11-11-2020, 08:31 PM   #17
Mike Barrett
I think it will end with the Mrs. yelling at me for buying it.
Old 11-11-2020, 10:26 PM   #18
J Franklin
J Franklin's Avatar
Anything you or she buys will at sometime need repair!
Old 11-11-2020, 11:57 PM   #19
Ak Sourdough
Originally the clutch wouldn't disengage, then there was a position where it works, then it won't move the car. So what exactly is happening, without knowing that nobody can help you.
Maybe you'd better hunt up a local Model A Club and have someone familiar with them take a look. Lots of guys about anywhere that are familiar with Model A's.
Old 11-12-2020, 07:29 AM   #20
Mike Barrett
went online to order a new clutch. They have "pressure plate-10" diameter". It is not a great picture, is this all I need? Thanks for all your help. I have contacted the local model A club (3 times but they have not responded as yet.
