10-17-2013, 06:22 PM | #1 |
Where is the vin # on 41 Ford sedan?
I looked on the frame rail on the drivers side near the horns and found nothing. I thought the '41 would be about the same location as a 1940. Have I not cleaned a big enough area or is the vin located in another place on a 1941 sedan?
10-17-2013, 08:23 PM | #2 |
Re: Where is the vin # on 41 Ford sedan?
It's in the approximate same place as your '40 Fords Bill. Look between the front cross member and cowl on the left frame rail. I have seen most nearer the cross member but on occasion have seen them stamped darn close to the cowl.
10-17-2013, 08:36 PM | #3 |
Most '41 numbers are very near the front crossmember on top of the left frame rail.
10-18-2013, 07:22 PM | #4 |
Thanks everyone. I found it farther back on the frame rail than normal.
10-22-2013, 10:15 PM | #5 |
When I pulled the front off my '41 it had no VIN on it anywhere on the frame, from the firewall forward. I installed a plate with the VIN on the firewall.
10-22-2013, 10:18 PM | #6 | |
Charlie Stephens |
