Old 10-25-2019, 11:18 PM   #1
1930deluxe
Default Exhaust manifold Gasket
There is at least five different exhaust gasket material offered. I want one that will hold up. What is the best manifold gasket to buy?
1930deluxe is offline   Reply With Quote
Old 10-25-2019, 11:24 PM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: Exhaust manifold Gasket
I like the copper clad original type. I also use the gland rings at the exhaust ports.
I feel this is very important but I am sure others may have a different opinion.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 10-26-2019, 04:04 AM   #3
old31
This is what I use with gland rings.
https://www.snydersantiqueauto.com/P...earchByKeyword
old31 is offline   Reply With Quote
Old 10-26-2019, 05:19 AM   #4
alexiskai
alexiskai's Avatar
I'm about to switch back to the copper gaskets to try to help with a vacuum leak.
Old 10-26-2019, 05:51 AM   #5
1931 flamingo
1931 flamingo's Avatar
The late 31 copper gaskets. They can be installed WITHOUT removing the manifolds. FWIW
Paul in CT
Old 10-26-2019, 08:10 AM   #6
1930deluxe
Thank you for your reply, you guys are the best.
Old 10-26-2019, 10:02 AM   #7
redmodelt
redmodelt's Avatar
When you take the manifolds off check for flatness. If the they are not all in a line or have heavy pitting get them surfaced as a unit. Also check the block in the area around the ports. Any deep pits around the (esp) the intake ports can be cleaned, filled and leveled with something like slow cure JB Weld. If you have the manifolds surfaced, dry fit to see if the gland rings need to be reduced in height to get gasket crush.
Copper is what we use, none of those fiber type. The fiber unclad burn out too fast but will work if you are in a pinch.
Old 10-28-2019, 05:47 PM   #8
chap52
chap52's Avatar
You can massage the gasket surface of manifolds and even heads by gluing a sheet of fine sandpaper onto a piece of glass on a flat surface. I use an old glass washing machine lid.
There is a neat video of a guy actually doing heads using this method...
Go to you tube and type in cylinder head resurfacing... Chap
