Old 08-12-2019, 06:46 AM   #1
32Bee
Default 36 Fuel Pump
I'm going to install an electric fuel pump in my 36 Fordoor Humpback. I'm tired
of grinding my battery down to nothing every time I try to start her. She's my
driver so I just want to get in, turn the ignition instant it up and go for a ride.
So, I've noticed some people install the electric unit and set it up so they only
use it to start the vehicle after it's been sitting for a while and some bypass
the original pump all together. Any clear advantage to either method or is it
strictly a matter of preference?
Will appreciate any comments you all have concerning this issue as I'm ready to
uncomplicate this part of my enjoyment of owning an early Ford.
32Bee is offline   Reply With Quote
Old 08-12-2019, 07:23 AM   #2
corvette8n
corvette8n's Avatar
Default Re: 36 Fuel Pump
Probably just a preference, my '41 has both pumps, the electric is on a spring loaded toggle, I hold it on for a few seconds until I hear the sound of the electric pump change then the car starts right up. The only disadvantage of my setup is if the mechanical pump fails I'd have to hold the switch on to get home.
Old 08-12-2019, 05:23 PM   #3
Pat/Ohio
Pat/Ohio's Avatar
Just to add what corvette8n posted....I have pretty much have the same setup on my cars except that my toggle switch has a spring-loaded side and an "On" side. So, if I need to keep my electric pump running for a while (in the city) I don't have to hold the switch on all the time.
Pat
Pat/Ohio is offline   Reply With Quote
Old 08-12-2019, 05:35 PM   #4
tubman
tubman's Avatar
That sounds like a great idea. Do you remember where you got the switch?
Old 08-12-2019, 07:28 PM   #5
Pat/Ohio
Pat/Ohio's Avatar
I believe I purchased the "momentary-off-on" toggle switch on epay! It's been probably 7 or 8 years ago. I will endeavor to do some researching (my old paperwork) to see if I can find something more definitive. Pat
Old 08-12-2019, 08:01 PM   #6
tubman
tubman's Avatar
I would appreciate it. I have looked and all I can find are ones that are momentary both ways. I did find one, but it was DPDT, which would work in a pinch..
Old 08-12-2019, 08:23 PM   #7
VeryTangled
VeryTangled's Avatar
Originally Posted by Peter in NH View Post
I'm tired of grinding my battery down to nothing every time I try to start her
Hi Peter, Suggestion #1 switch to an Optima battery. They are pricey but hard to piss off. https://smile.amazon.com/Optima-Batt...oding=UTF8&me=
Suggestion #2, I've had good luck with Shewman's check valve fuel hose. Stops fuel going back to the tank making the start harder. I can go about a week between starts without a lot of cranking.
Town is messed up in the photo.. Kimberton PA 19442.
Hope this helps.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 08-13-2019, 05:18 AM   #8
32Bee
I have an optima in my 36. I also have a later model fuel pump with a glass bowl. Even
though the bowl has gas in it she still won't start well. Most of the momentary toggle
switches have 3 terminals on Ebay. What's the reason for that?
Peter
Old 08-13-2019, 06:57 AM   #9
Pat/Ohio
Pat/Ohio's Avatar
Peter
Peter, My guess is you have 1 power wire to the toggle switch and 2 outs. 1 momentary and 1 constant out. Pat
