Old 08-16-2014, 05:21 AM   #21
30ccpickup
30ccpickup's Avatar
Default Re: Keeping engine compartment dry
Ask your question on a home improvement site. Your storage area needs to be ventalated to help with air movement and rapid tempature changes.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 08-17-2014, 03:45 PM   #22
TDO
TDO's Avatar
In my garage I layed down plastic before I poured the concrete, this gives you a vapor bearrier . I then lay down plastic where my coupe sets and cover it with a car cover.Keep a small light bulb under car. Works real good.
TDO is offline   Reply With Quote
Old 08-17-2014, 04:22 PM   #23
bikemaniac
I live in Denmark where the relative humidity in the winter is approx. 90%. If I have an unheated garage and circulate air by means of fans, I will also get 90% rel humidty in the garage. As a rule of thumb the rel humidity should stay below 60% in order to prevent rust on steel. For every % increase the chance of rust increases.
I suggest spraying it with a thin oil. I would love to use a dehumidifier, but here in Denmark where I live, 1 kWh costs the equivalent of 45 US cents = 0,45 dollar.
bikemaniac is offline   Reply With Quote
