Old 05-13-2011, 09:20 AM   #1
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Fordomatic fluid
This may have been covered before but I'm curious to know what the best trans. fluid would be for an early (1951) Fordomatic. the trans. has recently been resealed, the mechanic is gone and I don't know what he used but it still has some drips. In the old days we used Type A but it's no longer available and for years I used Dextron II. I'm thinking that maybe the present fluid is too thin and should be changed. Anyone else have fluid experience? TIA , Barry B.
Barry B./ Ma. is offline   Reply With Quote
Old 05-13-2011, 01:28 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Fordomatic fluid
Type 'F' fluid is what I use and is what is recommended for all Ford-o-matic and
Merc-o-matic transmissions 1976 and earlier.
Most of the dripping I have had is coming from the shift shaft on the side.
It's apparent after sitting for a while and the fluid drains back from the converter.
Old 05-13-2011, 02:25 PM   #3
rotorwrench
rotorwrench's Avatar
Type F (some list it as type FA) is a very good fluid for FoMoCo applications. It is best to start with it right after an overhaul since it has some detergent type qualities to it. Type A was the first type and it was a lot like MIL-H-5606 hydraulic fluid used in aircraft. I'm sure you could still find it somewhere but type F is good stuff if it's right out of overhaul.
Kerby
Old 05-13-2011, 07:58 PM   #4
paul2748
paul2748's Avatar
DEXRON III or Type F is the preferred. Original was Type A, not sure it is even made today. I have heard that the Dexron III is the preferred, but i used Type F in my 56 with no problems.
Old 05-14-2011, 07:50 AM   #5
Barry B./ Ma.
Thanks guys, I guess Type F or Dexron III will be the choice.
Old 11-28-2011, 01:22 AM   #6
Bessie
Bessie's Avatar
When installing a converter, should it be filled with fliud before the installation?
The mountains are calling and I must go! John Muir
Bessie is offline   Reply With Quote
Old 11-28-2011, 03:15 AM   #7
40 Deluxe
You can fill it before installation if you like a big mess when you go to stab it! Just pour in a quart or so for initial lube and let the pump fill it when you start it up.
