Old 05-10-2010, 11:53 AM   #1
Steve Plucker
Default Routing of very early windshield wiper wire...
What is the correct routing of the windshield wiper wire on very early 1928 (1927 vehicles) closed closed cars?
Thanks.
Pluck
Old 05-10-2010, 12:20 PM   #2
V4F
V4F's Avatar
Default Re: Routing of very early windshield wiper wire...
steve , i thought they were vaccumm ?? i have a vaccumm tube in my '31 .. steve
V4f
V4F is offline   Reply With Quote
Old 05-10-2010, 12:31 PM   #3
jrelliott
jrelliott's Avatar
My 28 Briggs body, the wire for the wiper was routed up by the left front door and across the header. There was a groove in the front door post and header for this. Came out of junction box, across front of fire wall and there was a wire holder on the fire wall above the steering column with a rubber groment in it as there was one on the brace under the gas tank to hold the wire until went up side of door sill. Just be careful when installing upholstry and not put a tack through the wire as will cause a short.
jrelliott is offline   Reply With Quote
Old 05-10-2010, 03:25 PM   #4
Marco Tahtaras
Marco Tahtaras's Avatar
What makes you think it's different than later models? Look for remains of two grommets inside and near the base of the right windshield post. There should be a round grommet in the support gusset about even with the rear corner of the gas tank and a triangular grommet where the belt rail ends inside the pillar or windshield post. You should also have a "U" shaped cutout at the top of the right windshield pillar moulding.
Marco Tahtaras is offline   Reply With Quote
Old 05-10-2010, 03:40 PM   #5
Steve Plucker
I will tell you why the early models are different than the later models so you will know yourself.
On the very early tanks, they had "a groove at the upper left corner of the instrument panel area to ACCOMODATE THE ELECTRIC WINDSHILE3D WIPER WIRE". (RG and JS, A-8 Revised 1997).
Obviously the routing is different on the very early modles...correct Marco?
Thanks.
Pluck
Old 05-10-2010, 03:44 PM   #6
Rowdy
So you are saying the groove in this instument panel I have is possibly an original feature. I thought it was someones modification, but for what had no idea. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-10-2010, 03:50 PM   #7
Rowdy
Just looked at the pic, and it appears this one is on the right side. Rod
Old 05-10-2010, 03:58 PM   #8
Marco Tahtaras
Interesting! Body number 514 (currently sitting on A217) has the wiper wire up the right pillar like the later bodies. Take a look at the top of your right windshield pillar moulding and see if there is a "U" shaped notch. Body 514 has the swing arm stud riveted on the moulding and appears to have the notch at the top like the later mouldings.
http://www.abarnyard.com/
Old 05-10-2010, 04:42 PM   #9
WTSHNN
WTSHNN's Avatar
Pluck
I recall a swap meet seminar a couple years ago (Grand Rapids???) with Dean and TK where they pointed out exactly what you were talking about on a tank that was lying around. Maybe one of them or Steve can chime in here.
WTSHNN is offline   Reply With Quote
