09-25-2017, 11:37 AM | #1 |
Changed Fuel Filter-Now won't start
1928 Model A. Car was running great however I noticed the filter in the globe was pretty dark along with some sediment at the bottom. I ordered a new filter, cleaned out the globe, replaced filter/spring/rubber seal and now the car won't start. It fired right up and I drove it for about 3 miles. Everything ran fine. I let it sit for about an hour with fuel line still opened, fired right up and ran for about 30 seconds and died. Will not start now. I pulled fuel line to make sure I had flow which I did. Could it be something in the carb? Could the fuel line have some kind of vacuum effect and it needs primed? Please help
09-25-2017, 11:59 AM | #2 |
Re: Changed Fuel Filter-Now won't start
assuming nothing else was altered .....it certainly sounds like fuel starvation...You say the fuel line has good flow. ...but one immediately suspects that may be fuel line is pushed too far into housing? ( I've been there, had that!) The olives should sit about 3/32 inch ( 2 millimetres ish) from the end of the line . Usually no vaccuum issues to over come unless no vent in filler cap... try it with cap off ,
09-25-2017, 12:10 PM | #3 |
Best to use the cork gasket to seal the glass. Ethanol will destroy rubber parts.
09-25-2017, 12:34 PM | #4 |
I had that problem after installing new screen filters. Culprit was a sticky carb needle valve. I pulled it out and used carb cleaner and a Q-tip. Took care of issue.
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
09-25-2017, 01:21 PM | #5 |
I know you say your line is open, but that 30-second thing sure sounds like when I occasionally forget to turn the gas valve back on after letting the car sit. It takes about 30 seconds to use up the gas in the carb before it runs dry. If not that issue, then maybe something got loose and lodged itself in the line or an internal port or venturi insice the carb.
Good luck. |
09-25-2017, 01:39 PM | #6 |
A friend installed a new filter and it wouldn't start. Turned out he had the incorrect filter installed and the gasket was partially covering the holes in the filter. Worth a check... |
09-25-2017, 01:54 PM | #7 |
Did you let the bowl fill after the filter change ? If the filter bowl is empty, bleed it. If it is full them remove the filter and try again.
09-25-2017, 02:33 PM | #8 |
Disconnect the choke rod assembly from the lower casting and take out the carb's center bolt from the bottom. It's a 9/16" hex head bolt. Cradle the casting in your hand as you lower it. If there is no fuel or a very low amount in the lower casting's bowl, the needle and seat are not functioning properly, as previously suggested. Or fuel is not reaching the carb, as also suggested. By dropping the lower carb casting, you can visually assure yourself the carb is getting gas, at least enough to start the engine. If the bowl's fuel level is correct (about 1/2 to 3/4 of the way full), then the problem lies elsewhere.
Marshall |
09-25-2017, 02:51 PM | #9 |
By the way, turn off the gas valve before separating the two carburetor halves.
M. |
09-25-2017, 02:58 PM | #10 |
Lots of good suggestions.
I noticed this is your first post.! WELCOME TO THE BARN!!! . Jeff
Let's let pylons, be pylons! |
09-25-2017, 03:38 PM | #11 | |
As a new member also, welcome to the new learning curve. |
09-25-2017, 03:43 PM | #12 |
i had plenty of fuel flow at the fuel line that connects to the carb with the new filter. I was also able to drive the car for a few miles right after I installed the new filter
09-25-2017, 03:46 PM | #13 |
Thank you. I will try that. If I let the car sit for a hour or so with the valve off and then turned back on right before trying to start I will get it to start for about 5 seconds before it shuts back down. And after that it won't start at all.
09-25-2017, 03:58 PM | #14 |
Thank you! I purchased my car knowing nothing about a Model A with the intent to learn and discover. I have had a lot of fun with it and look forward to learning as much as I can.
09-25-2017, 04:15 PM | #15 |
You should buy a bit of literature such as the owners manual and a good restoration manual. I have a booklet published by Ford concerning basic restoration guidlines.
http://www.ebay.com/itm/332389699754...84.m1555.l2649 Les Andrews has a few more in depth manuals that everybody seems to enjoy also. |
09-25-2017, 04:34 PM | #16 |
CRACK the line by loosening the nut at the carb, allowing some air out, fuel flow on, and eliminating a probable air bubble induced when you had it apart.
09-25-2017, 04:44 PM | #17 |
During one of my first experiences with a Model A I had the same problem. After turning the gas back on it Would run for about 5 seconds and then shut and not start again. I turned the gas off and waited just like you did and then turned it back on and had the same result. I am embarrased to say that I was turning the gas off when I thought I was turning it on and vice versa. That blunder made me miss riding in the 4th of July Parade. Hopefully that is your problem. Supergnat
09-25-2017, 05:44 PM | #18 |
I've seen the filter bowl gasket plug the outlet of the filter bowl
09-25-2017, 06:09 PM | #19 | |
OFF to the right; UP and running.
If at first you don't succeed, skydiving isn't for you! You don't need a parachute to skydive, you only need a parachute to skydive twice. |
09-26-2017, 01:03 AM | #20 | |
I made sure of that because when I pulled the fuel line I had it off and to test good flow I turned it on. Thanks |
09-26-2017, 01:06 AM | #21 |
so I tried it again this evening. Fired right up and ran fine for 30 seconds and then died and will not start. Starting to get a bit frustrated. Does anyone thing it has anything to do with the adjusting screw on top of the carb?
09-26-2017, 02:43 AM | #22 |
The screw is for adjusting the fuel/air mixture of the idle circuit..screw in to make it richer, out weaker. But I suggest you don't fiddle with mixturescrew at this stage ... Advise similiar to post #8 1) turn petrol off , 2) disconnect choke rod , unscrew large bolt at bottom of carb and remove lower half of body of carb ( careful you don't break the gasket and careful you don't bend long brass idle jet) 3) turn on petrol and see if it flows out of the upper body . If it doesn't pour out you have a blockage in en route somewhere. If it gushes out of top of carb look elsewhere for the culprit ( electrical? crud in lower body somewhere?).
09-26-2017, 05:19 AM | #23 |
Do you have the small aftermarket filter that fits in the top of the tank valve?
That's an important first step to avoid junk blocking the fuel. First flush the tank as well as you can, then install the filter. |
09-26-2017, 05:23 AM | #24 |
Start with the filter. Bleed it.
What kind of cover does it have ? Pot metal or glass ? If glass, you can see if it needs bleeding or not. If Pot metal, just bleed it anyway. Loosen the hold down screw enough to allow for the gasket seal to break loose and let the air out until the fuel flows. If you have already done this, then as Roseanne Rosanna Danna would say, never mind. The car ran fine before the filter change. Make sure the air is out of the filter. If it still doesn't want to run, remove the filter/screen and try it. Check the gasket and screen. Last edited by Patrick L.; 09-26-2017 at 01:04 PM. |
09-26-2017, 09:22 AM | #25 |
I agree with JohnBuckley - and not just because he agrees with me. The fact that the engine will run for about 30 seconds and die on a fairly consistent basis eliminates an electrical problem. That leaves two possibilities involving the fuel system: (1) The carburetor needle is hanging up in the seat and only allows gas to dribble into the chamber. If the car sits long enough (say, overnight or for a couple hours), sufficient gas has accumulated in the bowl to start the engine and run for a half minute before it dies due to lack of fuel. This is usually accepted as about the right amount of time a Model A engine should run with the on/off valve shut off and the chamber full. This time can be tweaked by lowering or raising the float level. Solution: either take the needle and seat apart and clean, or replace them. My bet is there is a Grose valve (ball) in your carb that is gunked up by Ethanol and is sticking, thus not allowing gas to flow into the carb. (2) There is a blockage in the on/off valve that will allow enough fuel to enter the carb after sitting for a while, but not enough to keep it running. Try this: turn the gas off, loosen the fuel line brass fittings at the sediment bowl and unscrew the one at the carb. Pull the line out of the carb and rotate it 180 degrees so that it is above the engine. Tighten the sediment bowl fitting so that the line stays at this level. Turn the on/off valve back on and take off the gas cap. Blow as hard as you can into the carb end fuel line. You should hear gurgling from inside the gas tank. If you hear nothing or you cannot get your breath to make the gas gurgle, the on/off valve is plugged with old cork bits from previous gas gauge floats or other gunk. Keep blowing until you break up the gunk inside the on/off valve. Once you hear the gurgling, the path is clear. The gunk will go back up into the tank, opening up the flow of fuel - temporarily. Reconnect the fuel line and tighten the brass fittings. Turn on the fuel and start the engine. If it continues to run, you'll know your on/off valve was plugged. Solution: drain the gas tank, remove the on/off valve and clean out any remaining gunk, inserting a pencil filter in the upper inlet (that goes into the tank). That will keep the gunk from gathering at the lowest place in your gas tank = the on/off valve.
Check these two suggestions out and get back to us. Marshall |
09-26-2017, 10:47 AM | #26 |
Bill Running Bill Pfffft
09-27-2017, 09:51 AM | #27 | |
Thank you |
09-27-2017, 09:53 AM | #28 | |
