06-18-2017, 12:05 AM | #21 |
Re: Head bolts
I was told that the head is a 5.2 from H&H, as is the engine.Looks a lot like the police heads with the big B on them that I have in my roadster and my coupe. Both of those came from private parties. I can't say who made them. Both are working well for me with the coupe having 94 psi in each cylinder. The roadster not so much, About 70 psi as I recall. Lower than the block I know nothing about anyway. The coupe had the police head on it when I purchased it.
06-18-2017, 03:04 AM | #22 |
Re: AntiSieze and Head bolts
Good thread (no pun intended) in our sister journal.
Don't torque dry threads and don't oil threads leaves one with > tada > antisieze. http://www.garagejournal.com/forum/a...p/t-72963.html |
06-18-2017, 08:20 AM | #23 |
Re: Head bolts
In my humble opinion:
If a law was ever passed that every time an experienced Model A owner broke a head bolt, (or any other Model A bolt), that did "not" have "Anti-Seize" on it ....... that the guy who installed these Model A bolts without "Anti-Seize" would by law ...... have to visit this experienced Model A person, (in person) ........ and that without any doubt ...... both the "U. S. Assault and Battery Rates" .... and the "U.S. Murder Rates" could increase tremendously in all (50) States. |
06-18-2017, 09:37 AM | #24 |
Re: Head bolts
If you cannot determine or are super concerned about the uniform flatness of the engine block surface known as the deck remove the engine and have your machinist deck it. This will eliminate all the the unknown and dumb things performed in the past. A good fitting quality head gasket should be able to compress under load and absorb +/- .0025 amounts of surface variations. I wouldn't take any chances especially since you are raising the compression ratio. This would also be a good time to redo the valves if they need regrinding or hardened seats.
Remember torquing and retorquing many times is is very critical. I would add a ceramic additive sealer to clean distilled water in cooling system and cycle the coolant according to directions. This will aid in sealing very small cracks and gaps within the cooling passages. Yes, Model A engine castings have many small cracks. |
06-18-2017, 11:31 AM | #25 | |
Re: Head bolts
Charlie Stephens |
06-18-2017, 12:51 PM | #26 |
Re: Head bolts
06-18-2017, 02:57 PM | #27 | |
Re: Head bolts
06-18-2017, 03:36 PM | #28 |
Re: Head bolts
The Best gaskets 573 is a better fit for the higher compression head. I always use the 573G
Graphite one sprayed with copper coat. In the old days the trick was to coat the studs with milk of magneasa before all the anti seize stuff was around. May be Fel Pro doesn't recommend anti seize on head bolts where the torque is on the coarse threads effecting the torque applied. I have always used antiseize on head studs on the coarse side and on the stud shaft to aid in cuter removal. Use oil in the fine threads to correctly torque the head bolts. Using antiseize or ARP moly will over torque the head it cuts down the friction and over stretches the studs. |
06-18-2017, 06:25 PM | #29 |
Re: Head bolts
Sounds exactly like the engine that was in my pickup when I bought it. If I had it to do over again, I would trash the engine and start over with a good one from another reputable source.
06-18-2017, 11:20 PM | #30 | |
Re: Head bolts
If the surfaces are flat The Secretes of Speed Society recommends using no sealant on Best Graphtite Gaskets. Last edited by Y-Blockhead; 06-18-2017 at 11:27 PM. |
12-17-2017, 08:48 PM | #31 |
Re: Head bolts
Can one use Permatex Ultra Blue on the cylinder head bolts as "anti-seize/sealant
What happens to the anti-seize/sealant when the bolts are re-torqued 3 times after running the engine? Is it rendered ineffective as a sealant? thx alan |
12-17-2017, 09:28 PM | #32 |
Re: Head bolts
I only use antiseize compound on the coarse threads on the studs that enter the block . The head nuts need some friction to reach final torque without stripping the threads .
12-17-2017, 10:28 PM | #33 |
Re: Head bolts
Torque values are used to stretch as fastener to hold it in tension without a locking fastener or compound.Its important to check the tapped holes in the deck,grey iron doesn't have the elasticity the stud has. Anti-seize is effective,Im leaning toward using a 'releasing' anerobic sealant (loctite blue threadlocker) on the coarse threads,it will help support the weakness of the tapped grey iron,I plan on running grade 8 studs and a 6 to 1 head raising the torque value to 65 pounds to properly stretch the harder stud. That's a whole lot of pull on the grey iron..figure the blue loctite will provide support yet release the stud on removal..
12-18-2017, 07:36 AM | #34 |
Re: Head bolts
Listen to what Richard Faluka (sp?) from Antique Engine Rebuilders says about the process they use for head stud replacement. They don't fully seat the studs in the block.... The video is long, but well worth a listen.
https://www.youtube.com/watch?v=N5kDrtTJGsU |
