Old 09-22-2020, 04:01 PM   #1
ronn
Default mud coming out of my engine???????????
you read that right. what gives? just flushed the rad and its clear.
will do the motor when it cools down in about an hour.
went through this last summer when I got the car.........
Old 09-22-2020, 04:52 PM   #2
arnhemmer
Default Re: mud coming out of my engine???????????
Could be water in the oil.
arnhemmer is offline   Reply With Quote
Old 09-22-2020, 04:57 PM   #3
eagle
eagle's Avatar
Mud???? Where is it coming from? What makes you call it mud? You need to give details and preferably pics or all you're going to get is a bunch of wild guesses which are useless.
Old 09-22-2020, 05:14 PM   #4
Patrick L.
Patrick L.'s Avatar
If you're talking about the cooling system, I can understand. Sounds like you car has been run on water for quite awhile.
You can take the side hose connector off and clean around the rear 2 cylinders. You'll probably get a lot out of there.
Old 09-22-2020, 05:21 PM   #5
ronn
well it looks like mud coming out of the drains and up at the opening to the rad.
just flushed the engine out, rad out and all water now looks "clear" as it did last summer.
I will run it some and see if it continues or clears up. When I bought the car, the daughter of the owner, who is now 75, said the car often overheated. Never had a better running motor. I have checked the oil and dont see any water........
wonder if the guy over packed the bearings with grease and this is the result?
I will try and get a photo or two.
Old 09-22-2020, 05:23 PM   #6
ronn
I would agree- but the car came from VT and was full of antifreeze when I got it. I drained it over the winter and left it empty. will fill with anti for this winter.
Old 09-22-2020, 05:38 PM   #7
Big hammer
Some Quick lub places pump grease until it falls on the ground, maybe they pumped grease until they run out of grease?
get a bigger hammer tap done
Old 09-22-2020, 07:32 PM   #8
Jack Shaft
Got sticks,rocks and acorns out of one.mud sounds reasonable.
Old 09-22-2020, 07:45 PM   #9
McMimmcs
McMimmcs's Avatar
A picture would help immensely.!
Old 09-22-2020, 08:10 PM   #10
walkerlakeprinter
walkerlakeprinter's Avatar
I got a whole bunch of cooked corn out of my radiator....and engine. Chipmunks had used the radiator for food storage one winter when I left the radiator open in the garage. Ugh. Finally got it all out and now I can run without overheating.
walkerlakeprinter is offline   Reply With Quote
Old 09-23-2020, 12:55 PM   #11
JD 1931
JD 1931's Avatar
maybe old grease from water pump...
JD 1931 is offline   Reply With Quote
Old 09-23-2020, 01:18 PM   #12
1928Mik
1928Mik's Avatar
My A's radiator was like that when I resurrected it from a 30 year slumber by Dad was responsible for. He had stored it with straight water in the radiator (heated garage). All that sludge and crap had dried up. Rad works perfect but I am still working to get it completely clear.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 09-24-2020, 09:38 AM   #13
ronn
Old 09-24-2020, 09:38 AM   #14
ronn
this looks like a chunk of grease, but mud was coming out everywhere.
