09-05-2019, 04:31 PM | #1 |
engine mounts torque
what is the appropriate torque for front engine mount bolts 85 HP engine. I'm guessing the biscuit is designed to give a little
09-05-2019, 05:23 PM | #2 |
Re: engine mounts torque
Just tighten it down until it's snug and the cotter pin fits. No specific torque.
You don't want to "squish" or crush the rubber mount. This is an 8BA but, same technique applies. Last edited by 19Fordy; 09-05-2019 at 08:59 PM. |
09-05-2019, 05:23 PM | #3 |
If you have the proper bolt, washer and nut, bring the slotted nut down far enough to engage it with a cotter pin.
09-05-2019, 06:29 PM | #4 |
