Old 12-05-2018, 12:02 PM   #1
1930deluxe
Default Rear Seat
1930 Tudor sedan rear seat question. What is missing the seat I have does not have brackets to attach the seat to the body?
1930deluxe is offline   Reply With Quote
Old 12-05-2018, 12:14 PM   #2
Dick Steinkamp
Dick Steinkamp's Avatar
Default Re: Rear Seat
You're missing the brackets.
Seriously, if you can post a picture of what you have, it would help.
The bottom cushion is not attached to the body. It slides in under the back cushion and is held in tension by the lower platform.
The upper cushion has 2 metal tabs on the wood frame that slide into slits in the structure supporting the rear panel.
Here are the tabs...
https://modelastore.com/index.php?ro...&category_id=0
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 12-05-2018, 03:43 PM   #3
jak
28-29 ( https://www.brattons.com/28-29-tudor...hion-clip.html )is different than 30-31 ( https://www.brattons.com/30-31-tudor...hion-clip.html )
jak is offline   Reply With Quote
Old 12-05-2018, 05:04 PM   #4
Dick Steinkamp
Good catch jak. Thanks!
Old 12-05-2018, 10:10 PM   #5
vern hodgson
The lower seat cushion has two metal brackets that are attached to the front of the seat cushion wood fame and seat in just behind the seat riser thus preventing the cushion from sliding forward
vern hodgson is offline   Reply With Quote
Old 12-06-2018, 01:11 PM   #6
1930deluxe
I will take a photo with a different camera and post it. For some reason it will not up load the picture from my cell phone. I will post one tonight.
Old 12-06-2018, 04:17 PM   #7
1930deluxe
I have attached photos of the seat that I have. I am not sure it is a complete seat. I think there should be a wood frame on the rear of the springs. I was told it is out of a 1928 tudor sedan.
Old 12-07-2018, 01:55 AM   #8
midgetracer
midgetracer's Avatar
That one looks just like the one i just upholstered from my 29 Tudor.
midgetracer is offline   Reply With Quote
Old 12-07-2018, 08:44 AM   #9
1930deluxe
How does the back cushion attach to the rear of the vehicle with no wood to attach the bracket? Could you send a picture of yours?
Old 12-07-2018, 10:01 AM   #10
midgetracer
There is two hooks on the inside of the body and the top of the spring wires clip into these hooks. I will try to get a photo later.
Old 12-07-2018, 11:05 AM   #11
Dick Steinkamp
Here is the backrest wood that all our vendors sell for 28-31 Model A Tudors...
Here's the picture of a Model A Tudor rear seat I posted on the OP's other thread on the same subject...
Here's the seat back the OP has...
They look different to me. The upholstery on the OP's covers some of the wood which makes identifying it tough, but the outside 2 vertical wood pieces on the top one should show on the bottom one and they don't.
I'd try a test fit in the Tudor. I could be wrong, or someone may have modified another seat to fit in a Tudor.
Old 12-07-2018, 11:07 AM   #12
vern hodgson
I agree, does not look right.
Old 12-07-2018, 11:25 AM   #13
Tacoma Bob
Tacoma Bob's Avatar
Interesting. I'm stumped. When I redid my Tudor this time last year the frame is identical to what Dick has posted. I don't recall ever seeing the "loop" retainers or the taper on the slats. Is it possible this is a Canadian built car. There were differences as well all know.
Tacoma Bob is offline   Reply With Quote
Old 12-07-2018, 11:59 AM   #14
1930deluxe
The seat I have does not have any wood at the top just open spring frame and the material is hog ringed to the spring framing. So if this was an early 1928 seat they may have been different than the 30-31? Midgetracer said his seat looks just like mine.
Old 12-07-2018, 12:13 PM   #15
TZBrown
According to the Clastique's PDF for Tudor page 4 some Tudors did have this frame
https://www.classtiqueupholstery.com...o_31_Tudor.pdf
Not sure of the mountings though, maybe give them a call
TZBrown is offline   Reply With Quote
Old 12-07-2018, 12:16 PM   #16
Tacoma Bob
Tacoma Bob's Avatar
Dang! someone has the answer. Just checked some of my books with no luck. I'm still thinkin Canadian or perhaps Phaeton rear seat backrest. Can't wait to hear more from Midgetracer.
Old 12-07-2018, 12:22 PM   #17
Dick Steinkamp
That could be it. Great research!
The next step would be a test fit.
Old 12-07-2018, 12:31 PM   #18
Tacoma Bob
Tacoma Bob's Avatar
Problem solved. Thanks TZ.
Old 12-07-2018, 06:37 PM   #19
midgetracer
Attached are the pictures I promised. My car is a 29 Tudor made in the Twin Cities. It is always been together and I am sure the wood and hooks are original. Hooks are as pictured earlier and are screwed to the wood below the window sides.
Old 12-07-2018, 06:41 PM   #20
midgetracer
The wire that the upholstery is hog ringed to slides over the hooks. I have a second Tudor that has the same wood. NO top wood, only the wood as shown in my pictures.
