05-01-2019, 04:26 PM | #1 |
1936 LB marking
If a 1936 engine has an LB marking, is it visible with the intake manifold installed? Is it always at the front of the left bank?
05-01-2019, 04:38 PM | #2 |
Re: 1936 LB marking
On the ones I've looked at, the LB marking is visible with the intake manifold in place - front of the left bank....
05-01-2019, 04:38 PM | #3 |
Re: 1936 LB marking
I have 3 lb blocks, none marked---- perhaps the oil pan can tell by shape or hammer dents out to clear front main bolts
05-01-2019, 06:09 PM | #4 |
Re: 1936 LB marking
I have a LB engine in my '34 PU. There are no marking (LB) stamped on the top of the engine. Another LB engine we have has the LB stamped on the top of the block. Who knows what Ford did? Mike
05-01-2019, 09:35 PM | #5 |
Re: 1936 LB marking
The LB blocks i have seen the stamping on was visible with the intake in place and location of the stamping was near the front but not sure what side.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
05-02-2019, 12:27 AM | #6 |
Re: 1936 LB marking
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
06-10-2019, 07:20 AM | #7 |
Re: 1936 LB marking
LB photo
06-10-2019, 07:48 AM | #8 |
Re: 1936 LB marking
That's the usual placement of the stamp.
It's been said that those stamps were placed once an engine was overhauled or some major service work performed after leaving the factory. It could be why so many aren't stamped to this day. Food for thought.... |
06-10-2019, 09:04 AM | #9 |
Re: 1936 LB marking
Here is another picture of an LB block stamp, in this ad-
https://www.fordbarn.com/forum/showthread.php?t=181366 My '34 has an "LB engine", however the top of the block is not stamped. |
06-10-2019, 10:45 AM | #10 |
Re: 1936 LB marking
Not sure about the LB being stamped after overhaul, but this engine was std bore from a 40K mile ‘36 5W. Engine was torn down, cleaned, new valves/lifters and new STD rings and bearings added. No machine work was required. The rebuilder even commented what I was doing was overkill as engine was all within tolerances and surfaces were excellent.
05-02-2019, 12:04 PM | #11 |
Re: 1936 LB marking
I have to ask, what is a LB block?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
05-02-2019, 01:39 PM | #12 |
Re: 1936 LB marking
05-02-2019, 12:37 PM | #13 |
Re: 1936 LB marking
Chris, it's a 1936 21 stud flathead with insert bearings versus babbitt. 36 was the first year that the changeover started taking place.
05-02-2019, 01:26 PM | #14 |
Re: 1936 LB marking
Does anyone know the correct meaning of the term LB Engine?
LB LATE BLOCK ? LB LARGE BEARING ? LB LARGE BLOCK? I’ve heard different people say different meanings. Bob |
05-02-2019, 02:13 PM | #15 | |
Re: 1936 LB marking
I also have several '36 LB engines that do not have LB stampings on intake deck.
05-02-2019, 02:39 PM | #16 |
Re: 1936 LB marking
Beware of frauds stamping a reg block to get a better prrice.
05-02-2019, 05:07 PM | #17 |
Re: 1936 LB marking
From what I've read,the LB main bearing studs are 4-1/4 inches apart on center.
05-02-2019, 02:37 PM | #18 |
Re: 1936 LB marking
05-02-2019, 05:42 PM | #19 |
Re: 1936 LB marking
Okay I hope I get this right but hopefully Brian will chime in to correct me. New Zealand 36 LB engines out of Canada have a hole in the front of oil pan rail about 1/2 diameter at front between water pump & crank seal casting opening in front of block. Very easily distinguished
05-03-2019, 02:38 AM | #20 |
Re: 1936 LB marking
KiWinUS is correct as regards Canadian blocks; all Canadian blocks since and including the 36 LB block, have an approximately 5/8" dia hole in front of oil pan mating surface, behind the pulley. They also have another similar hole at rear of oil pan mating surface which is only visible with the pan removed. I can only assume these two holes were machined to locate the block into fixtures for subsequent machining operations in the factory.Anyway, as that front hole is easy to see/feel, if a early style block, ie pump in head, is found that carries said hole, it is a 100% sure indication that it has liner bearings [LB block]. No babbitted main bearing engines carry this identification.
Again, USA LB blocks do not have this feature, Canadian only!
