03-29-2005, 02:51 PM | #1 |
Guest
Posts: n/a
55 Ford Restoration
I am in the process of restoring a 55 Ford, 2 door Fairlane. It has a 272 Y-Block. I would like to put a late model engine and automatic transmission. I would like something that looks sharp and has reasonable amount of power. I would like something as close as possible bolt in. Give me some ideas. Thanks |
03-29-2005, 03:29 PM | #2 |
Guest
Posts: n/a
Re: 55 Ford Restoration
302 or 351 is the usual swap. The 351 is a tight fit but it will go in. Suggest you post this on the Late V8 forum (top right of opening page). Lot's more discussions re: this over there. Also check the archives at the top of the Late V8 openeing page. Good luck! |
03-29-2005, 09:13 PM | #3 |
Guest
Posts: n/a
check front cross member these rotted out on a lot of them. major job if you find out after the motors in. has to come out again. cant be done with motor in the car. ken ct. |
03-30-2005, 04:07 AM | #4 |
Guest
Posts: n/a
Not trying to perpetuate a non-Flathead thread but won't most or all Ford FE's bolt in anyplace a Y-Block originally sat? |
