Old 08-19-2018, 10:40 AM   #1
braol
braol's Avatar
Default Thread size tie-rod 'plug'?
I have a seized tir rod end plug (the threaded end that screws down against the inner spring/ball). I am currently cutting out the plug and want to chase the inner threads before installing a new plug. What is the thread size? It appears to be fine pipe threads but I could be wrong...
"I have not yet begun to defile myself."
-Doc Holliday
'31 Tudor, '69 F100, '66 Mustang, '11 Ford Flex
braol is offline   Reply With Quote
Old 08-19-2018, 12:00 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Thread size tie-rod 'plug'?
Here is an old "thread" on the subject..
https://www.fordbarn.com/forum/showthread.php?t=23581
I don't think they ever got around to answering your question, but these recent pictures show what I measured...that is a SAE 20 pitch gauge....hard to read in the picture.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-19-2018, 12:14 PM   #3
redmodelt
redmodelt's Avatar
It is straight thread not pipe.
Old 08-19-2018, 01:06 PM   #4
100IH
Assuming you don't have one, The tool of choice would be an enormous screw driver tip that fits a 1/2" ratchet, fits like a glove is by far the best.
100IH is offline   Reply With Quote
Old 08-19-2018, 03:14 PM   #5
denniskliesen
denniskliesen's Avatar
There Snap-on sockets in various sizes that they made, and they are called drag link sockets.
denniskliesen is offline   Reply With Quote
Old 08-19-2018, 03:46 PM   #6
Bob Bidonde
Bob Bidonde's Avatar
The end plug has 60 threads per inch, so measure the major thread diameter to get the rest of the story.
Bob Bidonde
Old 08-19-2018, 09:28 PM   #7
denniskliesen
Bob, didn't you mean to say 20 threads per inch? 1955cj5 showed a thread pitch gauge on the nut 20 threads per inch.
Old 08-20-2018, 10:33 AM   #8
braol
braol's Avatar
I already broke the Bratton's Tie Rod End socket adapter tool. What I got is an end plug that will turn out about 1/4 of a turn and then just dead stops. It HAS to be the threads that are jacked-up. I can turn it back and forth...but, again, no more than 1/4 turn total of travel. I already bent a nice Snap-on screwdriver before I got the Bratton's tool.
-Doc Holliday
Old 08-20-2018, 10:55 AM   #9
braol
braol's Avatar
There is such a thing as a 1"-20 H4, Plug Chamfer Tap. This has to be what they used back in the day. A tap like that runs nearly $50!!! Let's hope it's not the threads...the attempt to insert a new plug will tell all.
-Doc Holliday
Old 08-20-2018, 11:42 AM   #10
denniskliesen
How much is a new tie rod end?
https://www.brattons.com/catalogsear...?q=TIE+ROD+END
Old 08-20-2018, 11:53 AM   #11
briphaeton
I think you need a 1 1/16x24 tap? Bratton's old catalog said it's 1 1/16 x 24 .
briphaeton is offline   Reply With Quote
Old 08-20-2018, 01:25 PM   #12
braol
braol's Avatar
That's what I was kind of getting at... I just like to preserve the original parts if I can...within reason of course...
A local machine shop I called says they'll chase the threads for me for $10 and a Coke.
-Doc Holliday
Old 08-20-2018, 07:23 PM   #13
redmodelt
redmodelt's Avatar
Ours is 1-1/16 X 20. braol, that would be the way to go. Taps that size are not cheap anyway.
Old 08-20-2018, 09:16 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
I had one that was stuck so bad it wouldn't turn even after I got the tie rod end white hot. It twisted the tie rod beyond saving.
Old 08-21-2018, 01:15 PM   #15
don3527
I have an archive print for the drag link, it is 1-1/16-20
don3527 is offline   Reply With Quote
Old 08-23-2018, 05:50 PM   #16
briphaeton
Thanks
