07-02-2017, 06:17 PM | #1 |
Generator driven tach?
Is anyone running a generator driven tach? I didn't know if the Model A had 3rd parties making them.
I have seen other cars of the era with the attachment at the end of the generator to run a cable. |
07-03-2017, 07:08 AM | #2 |
Re: Generator driven tach?
Get a generator from a MGTD.
07-16-2017, 10:33 PM | #3 |
I used a tinytach from Design Technology, Inc. They make a special one just for a model a
The sensitivity is too high on their std. model This tach is a TT-1C-RXL It is also a hour meter...... both digital readout simple hookup and needs no holes drilled...I ran the sensor cable through the firewall electrical box . |
07-17-2017, 01:43 AM | #4 |
Seems plausible the tach drive assembly from a Ford tractor could be mounted to the rear plate of a Model A generator.
Alternator versions are available too.
I Love Anything That Turns Money Into Noise |
07-17-2017, 07:55 AM | #5 |
That looks good. Now, how accurate would it be?
07-17-2017, 06:19 PM | #6 |
07-18-2017, 12:33 PM | #7 |
Generator belt slip makes tach readings unreliable. This was OK on my '61 Vette as when the tach quit working I knew my fan belt had come off. A common occurrence on high HP Vettes.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
