Old 04-22-2018, 01:07 PM   #1
Fast31
Default Any experience with transmission anti-leakage plugs
Has anybody installed this modification, 2 blind plugs that go into the holes of the bellhousing and that cover the transmission shifter-fork-shafts to stop the leakage of transmission oil into the bellhousing?
I am asking, because at the other side, the shifter tower has originally a similar design (blind bore for each shifter shaft), however the shafts have a groove on that side, to drain the oil from the blind hole, to avoid oil build up which may cause hard shifting.
If installing these blind plugs, do I need to grind grooves in the shifter shafts at the bellhousing-side? Or does the oil drain from the blind plugs via the notches of the shifter shafts?
Anybody on here that has put some miles on these blind plugs?
Fast31 is offline   Reply With Quote
Old 04-22-2018, 03:44 PM   #2
160B
160B's Avatar
Default Re: Any experience with transmission anti-leakage plugs
A friend recommends using ½ inch copper pipe caps, 25 cents at your local hardware store. Shorten the cap so it fits in the bellhousing shift shaft hole leaving enough room for the shift shaft to slide in and not have interference. If they drove in too hard trim the OD a small amount. Worked for me!!
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 04-22-2018, 07:03 PM   #3
CWPASADENA
CWPASADENA's Avatar
These plugs will not cause hard shifting.
I have about 10,000 miles after I installed these plugs on a Model A I use for touring.
No more oil leaking and no evidence of hard shifting.
My experience,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 04-22-2018, 07:07 PM   #4
1955cj5
1955cj5's Avatar
I did a similar install...used copper pipe caps....I soldered them together just because it seemed less likely that they'd work their way out.....
I did use plenty of penetrating loctite.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-23-2018, 05:12 AM   #5
Fast31
Thanks guys for sharing your experience and the good idea to use these soldering caps!
Old 04-23-2018, 12:27 PM   #6
Tom Endy
Tom Endy's Avatar
The small amount of oil leakage that will occur with a standard transmission using 600W oil, I believe was part of Henry's design. The oil runs down to the base of the bell housing and saturates the felt pad that sits atop the ball on the front radius rod to keep it lubricated.
The excessive leakage problem has occurred with the introduction of the Mitchell transmission. This transmission uses a much lighter oil and is prone to allow more oil to get past the shift rods in the tower.
This is why Mitchell developed a device that fits into the holes in the bell housing to seal off any oil leakage. Most of the suppliers carry it.
Tom Endy
Tom Endy is offline   Reply With Quote
