09-19-2018, 11:16 AM | #1 |
Frame year ID
Can some one date the year of production of this frame please?
09-19-2018, 12:09 PM | #2 |
Re: Frame year ID
Going by the emergency brake cross shaft it's before April 1930, can't
see the front cross member very well to tell if it's a 1930. |
09-19-2018, 12:21 PM | #3 |
Re: Frame year ID
How about using the serial number?
09-19-2018, 12:30 PM | #4 |
Re: Frame year ID
I have a chart that gives every month and year for every Modle a made. From first to the last It’s in my pictures. But Don’t know how or have a way to post it. If someone will pm me with e regular email address I’ll email it to them and maybe they can post it. It’s a really good chart
09-19-2018, 12:41 PM | #5 |
Re: Frame year ID
no fame number visible/decipherable
09-19-2018, 12:43 PM | #6 |
Re: Frame year ID
09-19-2018, 12:45 PM | #7 |
Re: Frame year ID
Look behind the first cab bolt,drives side top of frame
09-19-2018, 12:49 PM | #8 |
Re: Frame year ID
I say 1929 but not sure.
09-19-2018, 01:43 PM | #9 |
Re: Frame year ID
Steve Plucker has done exhaustive research on the subject. You can probably figure it out from the pages on his website -
http://www.plucks329s.org/frame.htm |
09-19-2018, 02:03 PM | #10 |
Re: Frame year ID
The 28-29s had holes for rhd and lhd steering in the frame rail and 30-31 only had lhd ,at least
at least in US cars. John Last edited by john in illinois; 09-19-2018 at 02:16 PM. |
09-19-2018, 03:17 PM | #11 | |
Re: Frame year ID
09-19-2018, 04:11 PM | #12 |
Re: Frame year ID
The radiator support bases appear to be raised but really hard to tell from your pics. If the are then it's 28 29.
09-19-2018, 06:42 PM | #13 |
Re: Frame year ID
It looks like the radiator mounting is dipped, which started in late 29.
1928-9 has round holes to mount the radiator, and 1930-1 has slotted. |
09-20-2018, 01:46 AM | #14 |
Re: Frame year ID
Thank you everyone
09-20-2018, 08:14 AM | #15 |
Re: Frame year ID
I was always under the belief that the middle cross member with the odd shaped holes (where they punched out the brake rod anti rattler brackets) was 1930 or later. I also thought that the 29 and earlier had square holes in that position. Maybe I am wrong.
09-20-2018, 10:53 PM | #16 |
Re: Frame year ID
You can see that the frame can be accurately dated as it is in the short time frame when the frame has been punched to take the solid bar emergency brake cross shaft. This frame has the earlier drop down hollow shaft typical of 28/29 .It will have factory blanking plates to stop the ingress of road dirt entering the brass cup bearing ends of the shaft. Ford brought out the frame holes then continued using up the early style . It is in the Service Bulletins around early 30 I think but cant find my yellow book right now.
John in very windy heavy rain Suffolk County England. |
