Old 01-19-2019, 10:23 AM   #1
ChistoLandman
Default 1930 Model A Ford
I dont have any spark to the coil, think it is an wiring problem. Any advice with the wiring to the coil, connecter box and to the ampmeter. Thanks.
ChistoLandman is offline   Reply With Quote
Old 01-19-2019, 10:41 AM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: 1930 Model A Ford
The problem could be the ignition switch . The best wiring diagram to follow is the one in Brattons catalog . I use to make my own wiring harnesses from purchased wire , I finally saw that the best and easiest way to go was the color coded harnesses that are sold by Bratton and others.
Old 01-19-2019, 04:32 PM   #3
burner31
burner31's Avatar
Some wiring diagrams for you
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 01-19-2019, 06:59 PM   #4
Dick Steinkamp
Dick Steinkamp's Avatar
You don't have power to the coil, or you don't have spark to the distributor on the high tension lead?
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 01-20-2019, 07:18 AM   #5
chap52
chap52's Avatar
Here is an informative trouble shooting video. Chap
https://www.youtube.com/watch?v=eXA6izLrTOc
chap52 is offline   Reply With Quote
