Old 06-27-2015, 08:14 PM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default condenser question
What is that great Napa condenser that's the hot no? I cain't remember if it's a IH-100 or IH-200. I think it's the 100. Thanks Walt
Old 06-27-2015, 10:07 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: condenser question
IH200 Echlin I believe.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 06-27-2015, 10:09 PM   #3
G.M.
IH-200 has the wire lead and IH100 has a stud. G.M.
www.fordcollector.com
Old 06-27-2015, 10:16 PM   #4
RKS.PA
RKS.PA's Avatar
Agree, Walt, it's the IH200 and if you can't find it I'll send you one gratis!!
Dick.
RKS.PA is offline   Reply With Quote
Old 06-28-2015, 06:40 AM   #5
adileo
adileo's Avatar
I have a 39 deluxe and ran with NAPA IH200 - I have a Bubba built 11A distro. Bubba said the IH200 is ok but will burn up the points faster. He suggested NAPA RR175 which I have since his suggestion installed.
adileo is offline   Reply With Quote
Old 06-28-2015, 07:37 AM   #6
G.M.
I haven't had or heard of any points being burnt with the IH-200 with cars over 25,000 miles over more than 10 year of service. G.M.
Old 06-28-2015, 07:44 AM   #7
adileo
adileo's Avatar
Bubba - I using ih200 on the 11a u built for me - what symptom would or remedy I could expect if I switch or not
NO REAL PERFORMANCE CHANGE , JUST MORE CURRENT THRU THE CONTACTS, MAYBE A SHORTER POINT LIFE.......IF ITS RUNNING GOOD DONT CHANGE IT....
Don,
I disagree , the IH200 NAPA is often used , however its a little low on capacity for the helmet distributor. The helmet likes .28-.36 mfds to work perfect.
I would use the NAPA RR175 (chevy v8 unit) or a .36 Vertex May unit....
If it Makes Spark, we do it !!!!
www.bubbashotrodshop.com
Old 06-28-2015, 09:12 AM   #8
Walt Dupont--Me.
Thanks guys. This is for my 40 with the 276 I've driven the hell out of for 40yr's. It's always run perfect with 4 of mad Max 97's. The other day it started to hitch at a high rpm. Haven't tuned it up for quite awhile. Took compression, 160# every cyl, 3# on the electric pump and good volume, removed the crab, cleaned the points, set .015, no one has a dist machine in my area, .015 has always worked good for me. Didn't have a new cond. so and couldn't remember if IH100 or IH200 so went to BARN, ( What WOULD WE DO WITHOUT IT) Always run a std 12 volt coil with the old poselin GM resister. So I think it's the cond. or the coil. This happens after the engine gets hot. 10am here, going to Napa right now see what they got. Will let you know how I make out. Walt
Old 06-29-2015, 03:40 PM   #9
Walt Dupont--Me.
40 is fixed, installed a IH-200 condenser, It will spin to 5K like nothing, don't want to turn it any faster, street light is coming up. Walt
Old 06-29-2015, 03:50 PM   #10
copperpenny
Is the IH 200 ok for Lincoln V 12?
copperpenny is offline   Reply With Quote
Old 06-29-2015, 04:59 PM   #11
B-O-B
B-O-B's Avatar
Walt if the brakes don't work make the horn louder.
heh heh hee
Good to hear you got it fixed. I took an old condenser & cut the top off then slid the IH 201 inside & soldered it in a spot to hold it make a ground. Just need to install it & see how it works. Mine is the 34 helmet & & the condenser fits in the coil.
B-O-B is offline   Reply With Quote
Old 06-29-2015, 05:03 PM   #12
uncle max
uncle max's Avatar
Quit babying it!
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is online now   Reply With Quote
Old 06-30-2015, 06:10 AM   #13
Walt Dupont--Me.
Originally Posted by uncle max View Post
Quit babying it!
I have a lot of googleing at your 4 97's hardly anyone have ever see that setup. Max, you da man. Walt
Old 06-30-2015, 06:21 AM   #14
RobR'35
RobR'35's Avatar
I would like to see pics of that set up.......
RobR'35 is online now   Reply With Quote
Old 06-30-2015, 07:20 AM   #15
G.M.
Yes but you need 2 of them. G.M.
Old 06-30-2015, 09:56 PM   #16
VeryTangled
VeryTangled's Avatar
-Jeff H
Old 06-30-2015, 10:36 PM   #17
VeryTangled
-Jeff H
Old 07-01-2015, 06:34 AM   #18
oldford2
oldford2's Avatar
No, that is not Walt in the picture. He is much younger.
John
oldford2 is offline   Reply With Quote
Old 07-01-2015, 07:39 AM   #19
Walt Dupont--Me.
When I'm driving that 40 I feel like I'm robbing the cradle, it's 4 years younger than me. Walt
Old 07-01-2015, 07:57 AM   #20
adileo
adileo's Avatar
Cool car!
