Old 04-10-2016, 05:12 AM   #1
HDowse
HDowse's Avatar
Default Access to gas tank sending unit
I need to check the gas tank gauge sending unit in the gas tank. Is there an access panel on top of the tank? I see a 6 inch or so circle of sealer on the mid left of the trunk floor. Is this it or is it hiding somewhere else?
Thanks,
Hunt
HDowse is offline   Reply With Quote
Old 04-10-2016, 05:22 AM   #2
oldskool
oldskool's Avatar
Default Re: Access to gas tank sending unit
yes there should be an access plate there one screw at 6 oclock
oldskool is offline   Reply With Quote
Old 04-10-2016, 05:26 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
That's where every one that I have seen is. The sealer was probably put there buy someone who was trying to make a boat out of the car.
Old 04-10-2016, 07:01 AM   #4
Terry,OH
Terry,OH's Avatar
For 1940 the cover should look like this.
Old 04-10-2016, 08:03 AM   #5
HDowse
HDowse's Avatar
Thanks the picture and for the responses. When I look at the trunk floor, where should the cover be located? Left of center, about mid-way front to back or someplace else? I don't see a cover like the one in the picture, just something similar with sealer and original paint on it. Hmmm?
Old 04-10-2016, 08:15 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
It may be a home made cover to replace a missing one. If that's the only cover, remove it to verify whats under it.
Old 04-10-2016, 09:27 AM   #7
Kube
Kube's Avatar
The factory applies a tar like substance to seal the cover. On occasion it was applies quite liberally.
You can see the cover quite well in the photo I have attached herein.
Old 04-10-2016, 10:04 AM   #8
ricklove
ricklove's Avatar
My access plate is on the left rear area, abut 12" in from the trunk opening.
ricklove is offline   Reply With Quote
Old 04-10-2016, 10:09 AM   #9
HDowse
HDowse's Avatar
That's it, just where you guys said it would be, very liberally covered with sealer. This gives me another project to jump into sometime soon.
Thanks, Hunt
Old 04-10-2016, 10:27 AM   #10
Joe Immler
Fun, ain't it ???
Joe Immler is online now   Reply With Quote
