Old 09-09-2019, 03:54 AM   #1
johnbuckley
johnbuckley's Avatar
Default Best location for master switch in a Tudor
I'm wanting to fit a battery master cut off switch inside the cabin of a 1930 Tudor (preferably on the "ground " side - not the live ). Where's a good place to fit it?
Old 09-09-2019, 06:08 AM   #2
springerpete
springerpete's Avatar
Default Re: Best location for master switch in a Tudor
Put it where you can easily reach it from your seat. It is up to you and how easily you move but it must be convenient to get to. Your choice.
springerpete is offline   Reply With Quote
Old 09-09-2019, 06:10 AM   #3
johnbuckley
yeah I agree, but I wondered if anyone had a good suggestion as to where those ideals exist in a Tudor ! ( along with a good earth to frame ideally)
Old 09-09-2019, 06:27 AM   #4
Ranchero50
Even if you are on the negative side of the battery once the switch is turned off one side will read 12vdc to the other if there is something turned on.
Ranchero50 is offline   Reply With Quote
Old 09-09-2019, 06:43 AM   #5
jwmckenzie
I mounted one in my pickup in the floorboard, It was just under my right leg close to the seat riser. Had to pick the location so it wouldn't interfere with the frame cross member. I am a big guy, in the middle, so was harder to get to than I expected.
I have also seen them mounted in the front of the seat riser, both on the left and center. You will have to make something to keep the things stored under the seat from getting to the switch lugs.
Great safety add to your A. Had a short in the starter switch that got pretty hot and smoky. as simple turn of the switch and the short was over. Easier to fix when everything is dead
jwmckenzie is offline   Reply With Quote
Old 09-09-2019, 09:09 AM   #6
monto
monto's Avatar
A choice could be; run leads through left most end of firewall to switch mounted on side panel at left of and above level of clutch pedal. Easy to reach and out of direct view..
'30 Coupe
monto is offline   Reply With Quote
Old 09-09-2019, 09:25 AM   #7
katy
katy's Avatar
Another choice would be a cable or rod operated remote disconnect switch.
Old 09-09-2019, 09:42 AM   #8
Tacoma Bob
Tacoma Bob's Avatar
Put mine between the seats. (30 Tudor)
Tacoma Bob is offline   Reply With Quote
Old 09-09-2019, 09:43 AM   #9
Dick Steinkamp
Dick Steinkamp's Avatar
There are also solenoid operated disconnects. Mount the switch in any handy spot. Here's one from Painless...
https://www.painlessperformance.com/wc/30204
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 09-09-2019, 11:42 AM   #10
johnbuckley
I was wondering about that but doesn't it get hit when tilting the seats to access rear compartment ?
Old 09-09-2019, 12:44 PM   #11
1931 flamingo
1931 flamingo's Avatar
Mine was under the driver's seat, out of site and easy to reach while in the seat.
Paul in CT
Old 09-09-2019, 02:16 PM   #12
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
Check out the Tech Topics on the Cedar Creek website. There's an article there for just what you asked.
Http://CedarCreekAs.org
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 09-09-2019, 03:06 PM   #13
Tudortomnz
Tudortomnz's Avatar
Mine is under floorboards at battery ; have a small spanner/wrench under mat, undo nut on strap to starter,remove. Simplest solution!
Tudortomnz is offline   Reply With Quote
Old 09-09-2019, 03:21 PM   #14
Tacoma Bob
Tacoma Bob's Avatar
I will try and take some pics and post. I have modified my seat brackets.
Old 09-09-2019, 03:31 PM   #15
Tacoma Bob
Tacoma Bob's Avatar
Here is how I mounted ours.
Old 09-09-2019, 05:26 PM   #16
Synchro909
Synchro909's Avatar
The previous owner had fitted a cut off swtich to my tudor before I bought it. He mounted it on the cross member with access through a hole in the floor board just big enough to poke your finger through. It is completely out of the way and if I put the small box I carry between the seats over it, it is invisible. Even without the box, all that can be seen is a slit in the carpet.
If I were to be installing another switch in a tudor, I'd put it in the same place.
Old 09-09-2019, 08:43 PM   #17
Pete
Pete's Avatar
I put them in the cross member, between the driver's legs.
Old 09-10-2019, 03:45 AM   #18
johnbuckley
Thank you everyone.
Old 09-10-2019, 12:01 PM   #19
slammin
slammin's Avatar
I installed mine under the driver's seat. While I was done there I added a second ground cable to the passenger side of the bellhousing.
slammin is offline   Reply With Quote
