Old 12-12-2013, 09:24 AM   #1
silvalms01
Default 37 Ford hood hinges
Are 37 Ford hood hinges one year only? Thanks, Pete
silvalms01 is offline   Reply With Quote
Old 12-12-2013, 09:56 AM   #2
Juergen
Default Re: 37 Ford hood hinges
The Green Book lists 78-16796 as the right hand hood hinge assembly for 37 only with a different number (91A- ) for 38-40. It then lists 91A-16797 as the left hand hood hinge for 38-40, ignoring a listing for a 37 Ford. So it looks like 37 is one year only.
Juergen is offline   Reply With Quote
Old 12-12-2013, 10:43 AM   #3
silvalms01
That's what I've been thinking. Thank you for your time, Pete
Old 12-12-2013, 07:18 PM   #4
swoopNZ
MEMBER EMERITUS
38 all and 39 std have an oval hole at the rear so you can adjust the side vents back and forth. Also the arms are not as wide.
39 deluxe and 1940 have a 5/16" UNF carriage bolt pressed in place as they have no side vents.
swoopNZ is offline   Reply With Quote
