12-29-2019, 10:50 PM | #1 |
Crank spring lube hole.
I have the good habit of when I have to look up something in the car manuals, I always read something else nearby. The subject action caught my eye.
my mental oil routine does not include this item... Turns out I have the front storage box which blocks access to the small hole in the crank bearing mount. I'll get after that soon with the special spring lube. |
12-30-2019, 02:07 PM | #2 |
Re: Crank spring lube hole.
You should be able to access it from the engine side below the radiator..........
Paul in CT Happy New Year to you and yours ! ! |
12-31-2019, 10:18 AM | #3 |
Bob Bidonde |
