Old 12-17-2022, 09:35 AM   #1
Conaway2
Conaway2's Avatar
Default Snap-On MT640 Coil Tester
I just acquired one of these - no user directions came with it, other than what’s printed on the unit itself.
It looks like it’s designed to test a coil installed in the car….
I would appreciate any guidance on how to hook this thing up.
Many thanks - Jim
Conaway2 is offline   Reply With Quote
Old 12-17-2022, 09:55 AM   #2
alexiskai
alexiskai's Avatar
Default Re: Snap-On MT640 Coil Tester
I did a video on it:
https://youtu.be/2X6LPS2zgUw
Old 12-17-2022, 01:44 PM   #3
Conaway2
Conaway2's Avatar
Thanks ! Great video - explains everything.
Jim
Old 12-17-2022, 01:46 PM   #4
Conaway2
Conaway2's Avatar
Jim
Old 12-17-2022, 03:15 PM   #5
Gene F
Gene F's Avatar
I am guessing that they no longer make these.
Gene F is offline   Reply With Quote
Old 12-17-2022, 03:39 PM   #6
alexiskai
alexiskai's Avatar
Correct, they’re usually found on eBay
Old 12-17-2022, 03:54 PM   #7
shew01
shew01's Avatar
The one I bought on eBay is missing the little neon(?) tube between the electrodes. Does anyone know what that thing is called or where I might find a replacement?
shew01 is offline   Reply With Quote
Old 12-17-2022, 04:49 PM   #8
alexiskai
alexiskai's Avatar
Those tubes are called Geissler tubes. No one makes them anymore, but if you search online for "discharge ampoule," you can find some tubes filled with chlorine, bromine, or iodine gas that are pretty similar and might fit the MT-640.
Old 12-17-2022, 07:10 PM   #9
shew01
shew01's Avatar
Thanks!
Old 12-20-2022, 01:32 PM   #10
katy
katy's Avatar
Will a neon bulb work there?
Old 12-20-2022, 02:34 PM   #11
alexiskai
alexiskai's Avatar
Probably. The tester works just fine with the tube missing. It comes into play when you have a really bad coil or condenser; the tube should light up when you switch the tester on to show that current is flowing, even though the coil is not able to create sufficient voltage to arc across the air gap. So really you could hook up anything there, an analog voltmeter, whatever. I think most folks are wanting to recreate the original look.
Old 12-21-2022, 12:31 PM   #12
katy
katy's Avatar
Electronics supply house, maybe an NE-51
Methinks I have some, PM me and I'll send you one.
Old 12-21-2022, 12:41 PM   #13
alexiskai
alexiskai's Avatar
A self-contained bulb like the NE-51 won't help much, you would need a bulb with wire leads. The neon tube sits between two opposing springs, as seen in the attached image.
File Type: jpg Screenshot 2022-12-21 at 12.39.40 PM.jpg (20.4 KB, 20 views)
Old 12-21-2022, 12:41 PM   #14
Bob C
I looked up that number and most seem to show 120 Volts, how well will
they work on a few thousand volts?
Old 12-21-2022, 12:59 PM   #15
katy
katy's Avatar
I have some like this, I could send, it's worth a try. Just protect your eyes in case the bulb "pops". Might need a resistor in series.
Old 12-22-2022, 12:26 PM   #16
katy
katy's Avatar
Here's a picture of an NE51, with wires soldered on, connected across the output of a Model T coil. If using one I would put something like a 47K Ω resistor in series with it. The output of the coil was measured at just over 20,000 volts.
