Old 04-02-2015, 05:55 PM   #1
Gary WA
Gary WA's Avatar
Default Cause:Extreme Backfire with Flames
What is cause(s) for extreme Backfire thru carb with flames out carb-retimed,checked distributor for shorts. Any other ideas./ Fellow members car with new engine.Stuck Valve(s)? Been driven for a while should have stated earlier
www.whidbeymodelaclub.com
Old 04-02-2015, 06:16 PM   #2
Mitch//pa
Default Re: Cause:Extreme Backfire with Flames
could also be adjusted to tight
Old 04-02-2015, 06:24 PM   #3
jax55
jax55's Avatar
Ditto Mitch.
Also. too lean or timing ( I know you double checked) cam too far advanced when installed with crank gear?
jax55 is offline   Reply With Quote
Old 04-02-2015, 06:26 PM   #4
WestCoast
sticking intake valve, weak or broken valve spring, run a compression check
WestCoast is offline   Reply With Quote
Old 04-02-2015, 09:19 PM   #5
P.S.
Timing 180 degrees out?
P.S. is offline   Reply With Quote
Old 04-03-2015, 09:17 AM   #6
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Condensers don't go bad very often, but it might be that. Easy to test for it.
Jacksonlll is offline   Reply With Quote
Old 04-05-2015, 10:20 AM   #7
CYB4
CYB4's Avatar
Just lost a nut of a cable at the ignition coil, was the same symptom before
Best regards
Chris
1930 Ford A Std. Tudor
CYB4 is offline   Reply With Quote
