Old 12-22-2018, 06:56 PM   #81
Liberty Garage
Liberty Garage's Avatar
Default Re: New Doodlebug Owner
Finally got the correct wheels and brake parts home from Eastern Oregon. The wheels are in rough shape, but that's ok, we know how to make them usable.
Made new rear lower cowl to frame wood spacers to replace the rotted out ones. Made them from an old pallet as the wood in pallets is generally pretty hard. Used new 3/8 carriage bolts on these mounts. Also installed new 1/2 carriage bolts from the rear axle mounts to frame.
Cleaned engine side of firewall with acetone and was fairly pleased with the results. Have been trying to decide what to leave somewhat original and what to paint. The acetone cleaned off the ancient grime and also slightly softened the underlying paint and transferred a film to the bare areas. Firewall looks pretty good now and no plans to do anything else to that area other than replace the missing panel to panel stove bolts.
Liberty Garage is offline   Reply With Quote
Old 12-27-2018, 10:46 AM   #82
OldTee
Firewall cleaned up nicely!
OldTee is offline   Reply With Quote
Old 12-27-2018, 12:49 PM   #83
burner31
burner31's Avatar
Easy way for pics:
Click the "blue post reply" lower left bottom of page, when text box opens, in the top middle of the bar you will see a "paperclip" next to the smiley face, click that, a window will open "manage attachments" click "choose file" then pick your picture, after you picked up to seven pics click the top "upload" on the right hand side of the text box, wait for it to upload.
You must type something, anything into the text box message, scroll down to see "preview post" at bottom of your text box, you should see your message as it will appear when you post, if you like it click "submit reply" to post.
Just make sure the picture file is not to large
Keith
Shawnee OK
'31 SW 160-B
