Old 06-23-2017, 06:21 PM   #1
fredski
fredski's Avatar
Default Wanting to check valve clearances
Do I have to remove intake / exhaust manifolds. I would rather not.
I do have adjustable lifters , it a AER MOTOR,with about 800 miles on it.
Fredski
fredski is offline   Reply With Quote
Old 06-23-2017, 06:46 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Wanting to check valve clearances
You can just remove the carb---thats all I did
Old 06-23-2017, 07:07 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
At 800 miles I wouldn't think an adjustment would be needed.
Old 06-23-2017, 07:10 PM   #4
fredski
fredski's Avatar
Thanks . Ido not want to disturb exh. manifold to muffler pipe since it perfectly fitted and not leaking.
Frd
Old 06-23-2017, 07:14 PM   #5
fredski
fredski's Avatar
Probably not ,but I hear a little engine noise at start up for a couple of minutes.
Fred
Old 06-24-2017, 06:26 AM   #6
2manycars
2manycars's Avatar
The engine noise at start up is more likely pistons waiting to expand, not valve lash. Call Rich and ask him what to do. If you have a Stipe cam, they are a bit more noisey than the original.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 06-24-2017, 08:25 AM   #7
Benson
Benson's Avatar
Old 06-24-2017, 08:56 AM   #8
Rex_A_Lott
A little noise in a cold engine is not that unusual. Worry about it if it doesnt go away when everything is at Normal Operating Temperature.Good Luck
Rex_A_Lott is offline   Reply With Quote
Old 06-24-2017, 09:01 AM   #9
Bob from Northport
Bob from Northport's Avatar
Its better to have the valves a little loose than too tight.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 06-24-2017, 09:05 AM   #10
zzlegend
zzlegend's Avatar
I am glad I am not alone on this. I did a mild rebuild on mine. Nice Babbitt, honed and new rings, and a stipe 330 cam with new big foot colony adjustable lifters set at 12 and 12 as per stipe instructions, up on start up, a little more clackedy clack then I thought they would be, but then quiets right down after the rpm's are brought up a little and a little oil flow.
zzlegend is offline   Reply With Quote
Old 06-24-2017, 10:05 AM   #11
katy
katy's Avatar
Wot's an "AER MOTOR"?
Old 06-24-2017, 10:34 AM   #12
Rex_A_Lott
https://aermotorwindmill.com/
Old 06-24-2017, 11:12 AM   #13
2manycars
2manycars's Avatar
Antique Engine Rebuilding
http://www.antiqueenginerebuilding.com
Bill
www.brauchauto.com
Old 06-24-2017, 11:55 AM   #14
Benson
Benson's Avatar
2manycars got it first
Old 06-25-2017, 10:00 PM   #15
fredski
fredski's Avatar
AER. A eager runner
Other information , noise on cold start up then seems to quiet up after a few minutes. Maybe I should leave it as is.
Old 06-26-2017, 01:31 AM   #16
Dollar Bill
Dollar Bill's Avatar
Fred, what weight oil are you running?
You may consider adding Lucas HD Oil Stabilizer... Designed specifically to address dry starts.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
