Old 03-18-2020, 11:25 AM   #1
Harpkatt
Harpkatt's Avatar
Default Shredding Fan Belts Alternator conversion
My Friend did a 12V Negative ground kit conversion in his 31' RPU(not sure of the make)he is now shredding belts. I know this is a common issue, can anyone point me in the direction of a thread that might have addressed this problem? It looks well aligned. I do have concern this belt is being overtightened, So I will start there.
Harpkatt is offline   Reply With Quote
Old 03-18-2020, 11:56 AM   #2
Jim Brierley
Default Re: Shredding Fan Belts Alternator conversion
This is not a common issue, so I don't know what to tell you. Over-tightening should not cause this, too loose might but you would hear belt-squeal. Perhaps the pulleys are not smooth? Maybe they are too small, not giving enough contact area?
Old 03-18-2020, 11:58 AM   #3
CarlG
CarlG's Avatar
Pulleys not aligned.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-18-2020, 12:05 PM   #4
Brentwood Bob
Alignment. The bracket maybe the main problem in my experience.
Brentwood Bob is offline   Reply With Quote
Old 03-18-2020, 12:30 PM   #5
DBrer
I have not had a belt problem with many miles driven, and mine is 12v.
DBrer is offline   Reply With Quote
Old 03-18-2020, 01:21 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
Look at pulleys for rust scales
How fully charged is the battery--- perhaps the alternator has to work too hard
Most cars with alternator the belt slips easy on the alternator pulley--- light finger pressure on the alternator fan usually cause slip -----
My belt is starting to look past it's prime---it's 45 years old, but the larger pulley the generator uses means the belt doesn't work hard
Old 03-18-2020, 01:50 PM   #7
DHZIEMAN
Based on what is being described with the fact you have proper alignment and the alternator is the new item (and is one with the proper pulley diameter for Model A's) and is shredding the belts, the problem appears to be the alternator. When it is charging is there any belt squealing? Does the Alternator pulley turn freely with belt off and engine off? I run a 6 volt alternator, which should make no difference and it worked fine the first time I started my A, and all the mounting hardware I built up myself. Other than what I am suggesting you look at as possiblities, I have nothing else to offer.
DHZIEMAN is offline   Reply With Quote
Old 03-18-2020, 02:22 PM   #8
1931 flamingo
1931 flamingo's Avatar
How could the alt be the problem?? The wrong pulley (depth and width) yes. JMO
Paul in CT
Old 03-18-2020, 02:24 PM   #9
rocket1
I would run a straight edge to the pulleys to check for alignment,I never heard of this happening,try a alternator pulley from Brattons and a new belt,make sure the tensioner bracket is holding it's adjustment and not loosening causing the belt to slip.
rocket1 is offline   Reply With Quote
Old 03-18-2020, 02:36 PM   #10
CarlG
CarlG's Avatar
A cogged belt helps.
Alaskan A's
Old 03-18-2020, 10:05 PM   #11
Mulletwagon
Mulletwagon's Avatar
Model As use a BX40, 41, or 42 cogged belt (which ever one fits).
Mulletwagon is offline   Reply With Quote
Old 03-18-2020, 10:20 PM   #12
Bill G
Bill G's Avatar
Alignment can be a tricky thing to sight exactly. I have a Nu-Rex 6v + ground and the bracket that came with it must be accurate because I have had no belt issues. If you don't know the source of the alternator or the bracket that holds it to the engine, I would suspect that as the cause.
Old 03-19-2020, 09:05 AM   #13
rotorwrench
rotorwrench's Avatar
The alternators are generally connected to the buss though a diode bridge and a voltage control unit. If the system has any high resistance due to wiring or terminals in bad condition, any shorts to ground, or a bad battery then it can work the alternator pretty hard. If the alternator diode bridge or voltage controller are malfunctioning then that can lock the alternator up pretty easy. If it locks up, you will usually hear the belts shredding.
Old 03-19-2020, 07:51 PM   #14
eagle
eagle's Avatar
Make sure the alternator pulley is the right width. Too narrow of a pulley will be tough on a belt.
