Old 12-10-2019, 10:12 AM   #1
Ian1932
Ian1932's Avatar
Default 32' Cowl to Firewall Gasket
I have an aftermarket gasket. Looks like the others that some forum users had to modify. I was wondering if anyone makes a good replacement? Or does one just not exist and i must modify the one i have? Thanks
Ian1932 is offline   Reply With Quote
Old 12-10-2019, 10:54 AM   #2
DavidG
DavidG's Avatar
Default Re: 32' Cowl to Firewall Gasket
My initial response regarded cowl vents seals, which, of course, was not the question. The reproduction firewall to cowl seals that I've seen bear little resemble to the original and are junk. I restore and re-use originals.
Last edited by DavidG; 12-10-2019 at 12:26 PM. Reason: Failure to read question carefully
Old 12-10-2019, 11:14 AM   #3
35fordtn
35fordtn's Avatar
A friend of mine in CA made me a small batch of 20 in the correct thickness (around 75% the thickness of those everyone sells) and they were made from Viton which is the most durable , They were very good, but it took us a long time just to sell those twenty. Unfortunately my friend Randy has passed away and the tooling seemed to have been scraped, so making another run is not possible.
So, we are back to selling the typical seal and it will work but is too thick as David mentions primarily it seems when using a original firewall. (at least from what I hear from customers).
Old 12-10-2019, 11:14 AM   #4
qmdv
qmdv's Avatar
I have a Brookville roadster and a Brookville firewall. The only thing i had to do with my gasket was cut just a little bit off. I am pretty sure the gasket come with the body form Brookville.
qmdv is offline   Reply With Quote
Old 12-10-2019, 03:41 PM   #5
Ian1932
Ian1932's Avatar
I found this gasket. Its used but seems to still be nice. It has threads in it. Is this more suitable even though its used?
Old 12-10-2019, 05:50 PM   #6
DavidG
DavidG's Avatar
That's the real deal - correct cross section shape and fabric reinforced. It is a hundred times more suitable despite being used.
Old 12-10-2019, 06:11 PM   #7
qmdv
qmdv's Avatar
getting that new with cloth reinforced is a dream. Just a dream
Old 12-17-2019, 03:04 PM   #8
alchemy
alchemy's Avatar
We recently tried four different gaskets (no original ones) and found the Vintique to be closest to original. My brother used that on his coupe. I used one of the others (I forget which manufacturer) by sanding it thinner on my belt sander. It's a messy job, and I wouldn't want to try test-fitting it on a car with fresh paint. Lots of on-and-off to get it just right.
alchemy is offline   Reply With Quote
