02-27-2018, 05:49 PM | #1 |
Tool question
Hi folks
Don’t yell at me if this is a really dumb question. I have a power saw. I use it for cutting wood shelves, etc. Do they sell a metal blade for these saws so I can use it to cut small metal projects on the cars?
Thanks - 30-9 1939, 1940 |
02-27-2018, 05:56 PM | #2 |
Re: Tool question
7" circular saw , yup at Home Depot / Lowes , metal cutting disc . They have one for concrete , don't get that one . It is a little hard on the saw . I usually use the $5 ones from garage sales for slicing and dicing metal .
02-27-2018, 05:59 PM | #3 |
Re: Tool question
https://www.ebay.com/p/Vermont-Ameri...d=162101519672 Wear eye, ear, respirator and body protection.
Just Passin' Thru.....Slowly! |
02-27-2018, 10:07 PM | #4 |
Re: Tool question
Better off with a 4-1/2" angle grinder and a .045 cut off wheel.
02-27-2018, 10:22 PM | #5 |
Re: Tool question
You should also have a sawsall. I just used it to cut my old brake lines and hoses off. Very handy to get into tight places.
02-27-2018, 11:55 PM | #6 |
Re: Tool question
02-28-2018, 11:20 AM | #7 |
Re: Tool question
I used to cut 1/2 thick alumium with a skill saw, just used a carbide tipped blade. Makes a really big mess with chips. Just be careful for kick backs.
02-28-2018, 11:31 AM | #8 |
Re: Tool question
Milwaukee, and others I suppose, make a metal cutting circular saw--The blade is more enclosed than a wood cutting circular saw--Probably much safer--I have a portable, hand held band saw that is extremely handy even for cutting heavy metal and pipe that is hard to get in my stationary band saw--With a long extension cord I can work quite far from the shop also--Eye protection with any saw is of most importance--
02-28-2018, 11:34 AM | #9 |
Re: Tool question
Also look at a body saw.
02-28-2018, 11:36 AM | #10 |
Re: Tool question
Reminds my of my early (pre engineering) Boeing days. I worked in tooling and we would cut thick sheets of aluminum (1 and 2 inch stuff) with these large air driven "skill" type saws. It was interesting to say the least.
02-28-2018, 12:29 PM | #11 |
Re: Tool question
Get a reciprocating saw (Sawzall is one brand). Many different blades available for most materials. I find a two speed version is best. Great for demolition if you have a home remodeling project. Nice thing is that they are very safe and don't throw sparks and hot metal chips. Easy to get into tight spaces like to cut a bolt. Just a all round, very handy tool. You can even cut shallow curves.
02-28-2018, 12:42 PM | #12 |
Re: Tool question
See, nobody yelled!
02-28-2018, 01:41 PM | #13 |
Re: Tool question
Thanks Guys! As always great advise.
I have a sawsall but it is hard to get straight, even cuts especially long cuts. thanks again for bearing with my lack of knowledge, but I'm learning thanks to you all!
05-19-2018, 09:56 PM | #14 |
Re: Tool question
I have used my table saw many times to cut aluminum plate up to 3/4 " thick. Good carbide blade, safety glasses, hearing protection and face shield are a must!
05-19-2018, 10:02 PM | #15 |
Re: Tool question
I picked up a chop-saw from a friend, cheap, and put a metal blade on it (10"). I also used a piece of 3/4" plywood between me and the fiber blade/disc. Guess I'm over safe and didn't want it fraggin' on me. Chopsaw was great for cut angles, etc...
Don't buy a cheap fiber blade/disc. Like an angle grinder blade/disc they are turning a huge rpm. Be aware, be safe! Faceshield.. armor... whatever. I like pirates with that cool eye patch, but I don't want to be one. . Last edited by Tinker; 05-20-2018 at 12:35 AM. |
05-20-2018, 01:03 AM | #16 |
Re: Tool question
A piece of angle iron clamped along the cut line will help you get straight(er) cuts.
05-20-2018, 06:52 AM | #17 |
Re: Tool question
For a 7 1/4" circular saw, I've used a plywood blade turned backwards to cut soft metals.
Assumption is the mother of all foul-ups. |
05-20-2018, 07:04 AM | #18 |
Re: Tool question
Buy some very good ear muffs. Buy a good sabre saw instead of a circular saw.
Circular saw is too dangerous IMO. |
05-20-2018, 07:09 AM | #19 |
Re: Tool question
19 Fordy used the application for a living no problem here. Did I say hear! lol
05-20-2018, 07:20 AM | #20 |
Re: Tool question
