Old 11-12-2022, 05:49 AM   #1
Tom Frew
Default Ford flathead v8 starter plate
I have a flathead v8 cast bellhousing. I need a starter plate. How do I figure out what one I need ? Would someone have a pic of the one for the cast bellhousing? Thanks
Tom Frew is offline   Reply With Quote
Old 11-12-2022, 08:08 AM   #2
Mac VP
Mac VP's Avatar
Default Re: Ford flathead v8 starter plate
There are several cast iron bell housings for the flathead engines. Perhaps you can post a photo of your bell housing and we can suggest the correct matching starter plate.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 11-12-2022, 09:03 AM   #3
Dick
Dick's Avatar
Here are a couple of different plates.
These cast housings are flat on both sides.
The starter plates both mount the starter flat as well.
I think, could be wrong, but the stamped bellhousing is flat to the engine but moves away from the engine for the starter plate. That requires a plate where the starter mounting point is at an angle to straighten the starter with the back of the engine.
I'm sure Mac is right about there being more designs; this is merely what I have. I hope others will add their wisdom.
Dick is offline   Reply With Quote
Old 11-12-2022, 09:35 AM   #4
jimvette59
jimvette59's Avatar
The starter plate you will need depends on the oil pan it will fit around . JMO
jimvette59 is offline   Reply With Quote
Old 11-12-2022, 11:35 AM   #5
V8 Bob
V8 Bob's Avatar
There are 3 full size car bell housings for '49-'53 flatheads;'49-'51 Ford, regular production '51 Mercury and '52-'53 Ford/Mercury.
The '49-'51 Ford uses the stamped steel bell and angled starter plate.
The '51 Merc and '52-'53 F/M cast iron bells use the same rectangle starter plate.
I put together a bell housing PDF many years ago with the help of member MOEFUZZ but cannot always post the link successfully, but try the link below.
bellhousing ID.pdf
Old 11-12-2022, 12:06 PM   #6
51504bat
51504bat's Avatar
The link doesn't work but the info and other good info can be found on these postings from the HAMB:
https://www.jalopyjournal.com/forum/...wnload.183227/
https://www.jalopyjournal.com/forum/...-help.1098730/
51504bat is online now   Reply With Quote
Old 11-12-2022, 12:42 PM   #7
outlaw
try this
outlaw is offline   Reply With Quote
Old 11-12-2022, 02:59 PM   #8
V8 Bob
V8 Bob's Avatar
Your first picture's starter plate is flat, and will work with that '48-'52 cast truck 1/2 bell, and the '49-'50 Merc stamped 1/2 bell.
The second and third picture show a similar cast 1/2 bell but with the wrong angled '49-'51 Ford starter plate.
Old 11-12-2022, 03:18 PM   #9
Tom Frew
Attempted to send a picture. My oil pan bolts to the bellhousing
Old 11-12-2022, 04:10 PM   #10
V8 Bob
V8 Bob's Avatar
Originally Posted by outlaw View Post
try this
Thank you outlaw. I can open my copies of that PDF, but cannot attach them to posts.
Old 11-12-2022, 06:24 PM   #11
outlaw
V8 Bob, I tried to attach it "opened" but can't seem to do it. There is 44 pages & the only way I could figger how to do it would be to attach every page separately. I didn't have time this am to do that. Hopefully it opens up for anyone that clicks on the link. Bill
Old 11-12-2022, 06:26 PM   #12
outlaw
Tom Frew, Hopefully the link will open for you. If not let me know & I can pm it to you. Bill
Old 11-13-2022, 10:38 AM   #13
Dick
Dick's Avatar
Thank you V8 Bob & Moefuzz !!
I got quite an education from your hard work and excellent report.
Thank you again!
Dick
