Old 01-27-2020, 07:25 PM   #1
ghalperin
Default Bronze Model A Ford Rear Main Thrust Plate & Oil Seal installation
My thrust clearance quadrupled after a 75 mile drive. It’s about .030 now.
I picked up this bronze Model A Ford Rear Main Thrust Plate & Oil Seal
I searched for info on the install, but I haven’t found anything. How do I remove the Babbitt thrust portion of the rear main? I was thinking of just scraping it off with a sharp scraper. There must be a better way.
ghalperin is offline   Reply With Quote
Old 01-27-2020, 07:43 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Bronze Model A Ford Rear Main Thrust Plate & Oil Seal installation
Read here- https://www.fordbarn.com/forum/showt...=bronze+thrust
There was a better step by step pictorial write-up on the barn but I couldn't locate it. Maybe someone else knows where it is hiding.
Old 01-27-2020, 09:42 PM   #3
ghalperin
Thanks for the link, it’s very helpful.
Old 01-27-2020, 10:36 PM   #4
ghalperin
Tonight I pulled the crankshaft and started whittling away. It took about 30 minutes with a breakaway utility knife. It almost looks like the end thrust was poured separately from the main bearing. There’s a dirty section in the center that looks like it was not bonded well with the thrust bearing part.
Anyways, the bronze part fits perfectly. I’ll check the end play after I get everything cleaned up.
I’m replacing the rod nuts with ARP nuts. Should I do the same with the main cap nuts?
Old 01-28-2020, 08:03 AM   #5
Mulletwagon
Mulletwagon's Avatar
Interesting post; please continue the story and photos. Thanks.
Mulletwagon is offline   Reply With Quote
Old 01-28-2020, 09:38 AM   #6
rotorwrench
rotorwrench's Avatar
I know this might be a touchy subject but I was curious about who did the babbitt bearing work?
Old 01-28-2020, 09:42 AM   #7
Dave in MN
Dave in MN's Avatar
ghalperin,
I have used over 150 of these combination thrust and seal in rebuilding A engines with insert bearings. To avoid a leak, bed the combination thrust and seal with a sealant. Permatex #2 works well.
Good Day!
Dave in MN is offline   Reply With Quote
Old 01-28-2020, 06:37 PM   #8
ghalperin
The engine was rebuilt in the '70s, I doubt if they're still around. The car was in Napa for decades.
Old 01-28-2020, 06:38 PM   #9
ghalperin
Originally Posted by Dave in MN View Post
ghalperin,
Good Day!
Thanks for the tip, I plan on it.
Old 01-29-2020, 01:12 AM   #10
redmodelt
redmodelt's Avatar
When doing new Babbitt, MAKE SURE THE THRUST FACES ARE AS SMOOTH AS THE JOURNAL ON THE CRANK. That means both ends. If they are not will act like a file and remove material same as a file would.
Old 01-29-2020, 04:50 PM   #11
Nosetime
Nosetime's Avatar
Glen, when I put mine back together I used ARP rod nuts and headstuds, like Jim suggests in his book. I also bought the modern sealed main bolt kit from Brattons or Snyders.
Nosetime is offline   Reply With Quote
Old 03-24-2020, 03:34 PM   #12
ghalperin
After completely disassembling, adjusting all the babbett's and reassembling, it still knocked. I sent the rods out to have the wrist pin bushings changed. When I was cleaning it up for reassembly, again, I noticed a small mark on the center of the combustion chambers and matching marks on two pistons. I only had .019" between the piston and the head. I had .020" shaved off the tops of the new pistons and all is good.
That little tit on the bottom side of the piston was expanding just enough to kiss the head.
Old 03-24-2020, 04:14 PM   #13
MikeK
MikeK's Avatar
Originally Posted by ghalperin View Post
. . . There’s a dirty section in the center that looks like it was not bonded well with the thrust bearing part.
That dirty looking section is actually torn apart alloy from internal porosity and shrinkage. Caused by a combination of dissolved gas from a lot of remelt in the heat, overheated alloy resulting in loss of nucleation points, and failure to immediately and properly compact the poured shells by peening after pouring. That caused the thrust face to easily compact in short order when the engine was run.
If it all happened in just a few miles as you state I question the integrity of all three mains, and not just the side faces. If the same guy did the rods you may be in for more problems.
As for your desire to change from stock nuts with cotters to ARP nuts, I'd call that overkill unless you're planning some serious mods and racing.
MikeK is offline   Reply With Quote
Old 03-24-2020, 05:33 PM   #14
ghalperin
Sorry to be misleading in my initial post. The engine has not been apart since the '70s. I was driving it a little too hard on the toll road and afterwards is when I noticed the nocking. All of the babbitt clearances were very close to .0015". I only ended up adjusting a couple.
