Old 02-11-2020, 09:08 AM   #1
Mart
Mart's Avatar
Default Tuesday Tech: Which valve to adjust? Mart's easy method.
I try and explain an easy way to work out which valve to adjust. Remember this principle: When No.6 Exhaust is open, No.1 exhaust is directly opposite the lobe. And so on for all the valves. I used the easier method and did both valves on each cylinder. It worked so well I thought I'd post up a simple tech video. This could be adapted to any motor and could be done from a distributor with some ingenuity. Thanks for watching. Mart.
https://youtu.be/MpfNt281XK4
Old 02-11-2020, 10:16 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Tuesday Tech: Which valve to adjust? Mart's easy method.
Thank Mart;
I was a little confused at first, but I learned something today, I have one bare block, one with stuck pistons and one complete engine to play with when the weather gets warm. I work on these in a portable garage it's supposed to get to -4F later this week. Looking forward to Spring.
Old 02-11-2020, 12:36 PM   #3
Russ/40
Russ/40's Avatar
That's a clever observation Mart. Your ability to coherently keep it straight mentally is impressive, but my undisaplenned brain can only manage the 1 full turn past peak opening on one at a time. That assures I don't screw it up. LOL
Old 02-11-2020, 12:44 PM   #4
Ol' Ron
Ol' Ron's Avatar
My brain is so full of useless information, that there is no more room for more. When the valve is open, rotate crank one revolution and adjust it. works for any cam. Ya just have to be lazy to fidder this out.
Old 02-11-2020, 01:14 PM   #5
RalphM
RalphM's Avatar
Good job Mart! I think that’s pretty simple.
Ol Ron,
In Marts setup with no crank, then you would turn the cam gear 1/2 turn if I am thinking correctly.
RalphM is offline   Reply With Quote
Old 02-11-2020, 06:00 PM   #6
Russ/40
Russ/40's Avatar
Ol Ron,
Oh yea, didnt think of no crank.
Old 02-11-2020, 06:42 PM   #7
Mart
Mart's Avatar
If you ignore all the preamble and just write the firing order around the timing cover mounting face like that, it'll work. Just align the cam gear timing mark with each number in turn and adjust both valves for that cylinder. You don't need to know how it works, just that it does work.
Thanks for all the interest. The video has had a good number of views.
I tried to find a thread on here where people's methods were being discussed but I couldn't find it. I was thinking of this as a response to that thread.
Mart.
Old 02-11-2020, 08:51 PM   #8
Ol' Ron
Ol' Ron's Avatar
Yes , Mart is doing a great job with the tools he hand at hand, He has a great deal Of Perseverance.
Old 02-12-2020, 05:37 PM   #9
Henry Hopper
Henry Hopper's Avatar
Can’t wait to see it run..... you’ve certainly got the patience of a Saint, Mart.Enjoying the videos, keep ‘em coming mate.
Henry Hopper is offline   Reply With Quote
