02-18-2012, 03:37 PM | #1 |
1930 model a rear drums Q.
Wanted to have a look at the rear brakes for ware and I'm having a hard time taking the drum off. Any advice?
02-18-2012, 03:51 PM | #2 |
Re: 1930 model a rear drums Q.
Have you backed the adjusting screw all the way OUT?
02-18-2012, 03:55 PM | #3 |
The hub may be the culprit. It stick on the axle pretty solidly - a little corrosion and/or binding from when the last guy tightened the nut on the end of the axle will lock it up tight. I fought with one a while and then borrowed a rear drum/hub puller from a friend - had it off in a minute. One tip: once you have tension on the puller, whack the screw head with a heavy hammer - that helps break the corrosion. Second tip - there are two styles of puller. One works on the protruding ring hub style, the other on the recessed ring hub style. See p157 in the '12 Bratton's catalog.
02-18-2012, 08:11 PM | #4 |
You need a big puller. The kind that attaches to 3 lug studs. Maybe you could borrow or rent one. I bought one from a Mac Tools dealer 25 years ago and it has never failed to break a drum loose without damaging anything. Be careful with those knocker things that thread on to the axle. You could damage the axle threads.
02-18-2012, 08:27 PM | #5 |
There are several types of pullers. The one I used does not thread onto the end of the axle shaft. It pulls directly on the hub and pushes against the end of the axle.
02-18-2012, 08:46 PM | #6 |
02-19-2012, 12:36 AM | #7 |
Another way, (has been suggested on the forum here before) is to loosen axle nut a thread or two and drive the car in a circle to loosen. If this doesn't work then use a hub puller.
Paul in CT |
02-19-2012, 10:17 AM | #8 |
I've found removing a stuck hub to be the most frustrating job ever in working on my A. I have one hub I swear became one piece with the axle!! I finally bought one of the expensive hub pullers (from Snyder's) and it worked immediately, after I had tried every other kind of puller and everything else--short of hammering on the end of the axle with a BPH, which seems to me a bad idea, bound to do damage somewhere.
02-19-2012, 12:18 PM | #9 |
This method might work, but when I was learning mechanics I was told this can mess up your keyways, so I've avoided doing it.
