Old 07-25-2019, 12:23 AM   #1
ford35lh
Default Truck oil pan
What year did Ford start using the truck oil pan
with the removable bottom plate ???
I have one on a motor that is going to the scrapyard.
Wondering if it is worth removing ???
ford35lh is offline   Reply With Quote
Old 07-25-2019, 12:29 AM   #2
Tinker
Tinker's Avatar
Default Re: Truck oil pan
thinking 40s on within the 59a/8ba.
to my thinking is save it. truck pans work well with late flatheads and model a's and early fords (anything with a straight axle). at the very least. waterpumps too. maybe bell housing.
Old 07-25-2019, 12:32 AM   #3
leon bee
I don't know if the ones on ebay sell, but they are always wanting at least $100 for them.
leon bee is offline   Reply With Quote
Old 07-25-2019, 04:45 AM   #4
marko39
The truck oil pans are needed for installing an 8 BA into prewar cars. Save it.
marko39 is offline   Reply With Quote
Old 07-25-2019, 10:26 AM   #5
Fordestes
Save the oil pump as well for rebuilding , I have had bad exper. with some of the new oil pumps
Fordestes is offline   Reply With Quote
Old 07-25-2019, 12:23 PM   #6
rotorwrench
rotorwrench's Avatar
The pre 8BA pans won't fit anything but a pre-8BA. Folks like the trap door pans for cars too. It makes it easier to replace any clutch or flywheel in an early Ford. I would check prices on flea pay for a while before listing it. Folks may pay more than $100 but likely not a lot more. Shipping is another concern for buyers. It would sell easy enough though and be worth taking it off and cleaning it.
Old 07-25-2019, 04:40 PM   #7
Ross F-1
Ross F-1's Avatar
Originally Posted by rotorwrench View Post
The pre 8BA pans won't fit anything but a pre-8BA. Folks like the trap door pans for cars too. It makes it easier to replace any clutch or flywheel in an early Ford. ....
How would it make a clutch/flywheel job easier?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 07-25-2019, 06:24 PM   #8
rotorwrench
You can actually get the flywheel out without pulling the oil pan. We aren't talking about 8RT set ups here but strictly 59 series and earlier V8s.
Folks have to be more specific on here. If you mean a sump clean out on the bottom of an 8RT oil pan then we are only taking about 8RT engines. If you are taking about the trap door set up on the early engines then it's only about them.
