Old 02-02-2018, 10:26 PM   #1
Hitchhiker
Default Can anyone in the Seattle area come help me trouble shoot my pickup
Got a 31 pickup that I can not get running for the life of me. I think it's timing. Buy not sure where I am going wrong. Been over it a dozen times. Most I've gotten is about 10 seconds of running. If anyone in the Seattle area wanted to stop by and help me that would be super awesome. Thanks Matt
Matt in Seattle
Hitchhiker is offline   Reply With Quote
Old 02-02-2018, 11:05 PM   #2
CarlLaFong
CarlLaFong's Avatar
Default Re: Can anyone in the Seattle area come help me trouble shoot my pickup
If it will run for 10 seconds, I doubt, very much, that timing is your problem. Most electrical problems are fuel related and vise versa. Check for sticking needle. Try another condenser
CarlLaFong is offline   Reply With Quote
Old 02-03-2018, 12:41 AM   #3
3.6rs
3.6rs's Avatar
If it starts and runs for 10 seconds you should look elsewhere.
3.6rs is offline   Reply With Quote
Old 02-03-2018, 01:41 AM   #4
Hitchhiker
I should say it's barely running and backfiring.
Matt in Seattle
Old 02-03-2018, 01:52 AM   #5
hardtimes
hardtimes's Avatar
Backfiring USUALLY is a symptom of a timing disorder. Do you have the plug wires hooked up to proper sequence for timely delivery of spark. Definitely will backfire is not correct.
Other reasons for backfire are numerous, like valves clearance not right; running out of fuel in cylinders; intermittent spark delivery ; faulty condenser; distributor not set correctly, and on.....
Make a list and check each one off as you proceed to analyze.
Old 02-03-2018, 01:53 AM   #6
capete
check fuel tank & line - blow them out!
capete is offline   Reply With Quote
Old 02-03-2018, 02:06 AM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Where in Seattle do you live? I’m at I-5 and south 272nd street.
Old 02-03-2018, 02:19 AM   #8
Synchro909
Synchro909's Avatar
Sounds like timing could be the issue. I had dramas a while back and the backfires from the car sounded like WW3. It turned out to be a faulty (from new) rotor button. It had virtually no lug on the inside to engage the slot in the cam. As a result, it turned on the shaft as it saw fit. Timing was all over the place. It took a while to find but when I found it, I had a grin a mile wide - gotya, you B@$t@rd!
Old 02-03-2018, 06:37 AM   #9
Marshall V. Daut
Could you possibly post a couple photos of your engine compartment from the passenger's side? This will tell us what is and what isn't present. That alone could provide suggestions about what to check. For example, one or two in-line filters between the sediment bowl and the carburetor will send up red flags for fuel delivery problems. Or a rat's nest of ad hoc wiring can also indicate where the problem lies. 'Might save the guys from going off on wild goose chases.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 02-03-2018, 08:12 AM   #10
1crosscut
1crosscut's Avatar
Take a quick peek inside the distributor to see if the flexible wire is frayed or shorting out.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 02-03-2018, 01:24 PM   #11
Gary WA
Gary WA's Avatar
look at www.mafca.com chapters in your area,Evergreen A's etc. they will come!!
www.whidbeymodelaclub.com
Old 02-05-2018, 03:02 PM   #12
Hitchhiker
I'm by Northgate mall
Matt in Seattle
Old 02-05-2018, 05:25 PM   #13
JBill
Sputtering and backfiring could be a manifold leak or other vacuum leak. Check carb gasket. Grasping at straws here.
JBill is offline   Reply With Quote
