08-28-2017, 11:21 PM | #21 |
Re: Were any of the 40 sedan deliveries built as standards
The Panel Delivery will have two rear doors and the Sedan Delivery only one. And while the 112" wheelbase Panel I mentioned previously looks to use the automobile hood that is not the case. The truck cowl is different and the rear of the hood has a different shape to fit the larger cowl.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
08-28-2017, 11:28 PM | #22 |
The sedan delivery was styled more after a car while the panel delivery was styled after the truck line. I think the problem is that the two are commonly misnamed. I see SD's called PD's and PD's called SD's. I also see many SD'd labeled as "Deluxe" and I wonder if that isn't just tacked on because they were more deluxe than the panel deliveries.
08-28-2017, 11:56 PM | #23 | |
The deluxe and panel labels may have started with the Model A. Ford called the car-style delivery deluxe and the truck-ish one panel. |
08-29-2017, 01:42 AM | #24 | |
08-29-2017, 06:56 AM | #25 |
Both are 112" WB. the Panel has an outside spare tire and tail light on the rear door and larger interior. The Sedan delivery has the spare tire inside and tail light on the fender the interior is about 8" shorter and nearly 10" shorter in height, than the Panel.
08-29-2017, 08:45 AM | #26 | |
08-29-2017, 08:47 AM | #27 |
Okay guys, I had a chance to go through all of the pertinent documents I have in my library respective of exactly what Ford built in 1940. There are no records of a Ford V8 (aka "Standard") SEDAN DELIVERY being built.
Until someone can find some documentation that states otherwise, I will have to continue to believe no such vehicle was built. The so called "authentication" of the vehicle witnessed (earlier post) I believe to be contrived. Authenticated by who? It is simple to swap the respective parts from the Ford V8 model to the Deluxe - absolutely simple. I have no doubt that's what was witnessed as "authenticated".
08-29-2017, 09:11 AM | #28 |
My guess is that the 1941 sedan delivery messes with folks head since it looks like a cross between a 1941 pickup and a 1940 standard. Too many folks assume things are correct without doing the due diligence and actually finding the documentation. Some of the real early 1941 SDs may have been sold and titled as 1940 models by mistake. Some states titled stuff the year that you did the transaction and not for the model year of the vehicle.
08-29-2017, 09:53 AM | #29 |
Found this on the HAMB. For your viewing pleasure.
08-29-2017, 10:14 AM | #30 |
That is a '41 SD as witnessed by the trim on the hood and the recessed gas filler. While not as clean as the gas door on later models the 1941 was better looking than the more prominent filler on the '40.
08-29-2017, 10:21 AM | #31 | |
08-30-2017, 04:35 PM | #32 |
From what I have gleaned from this thread, chances are, if you see a 1940 Ford Standard Sedan delivery, it will probably be sitting next to a 1940 Ford Standard Convertible Coupe!
08-30-2017, 05:13 PM | #33 |
I have seen 40 std. deliveries. However, I CANNOT testify as to the originality.
08-30-2017, 06:25 PM | #34 |
I have also seen 40 V8 (std) convertibles but I don't think they were assembled by Ford. My original 40 Showroom price poster only shows the Convertible Club Coupe listed with the Deluxe cars, not the V8, or V8 60 list.
Too bad Commercial vehicles aren't listed too. |
08-31-2017, 11:10 AM | #35 | |
Milt/Las Vegas |
08-31-2017, 12:24 PM | #36 |
In looking for supporting information , there is a paragraph on page 140 of ' The Classy Ford V8 ' by Lorin Sorensen. It states that after 1940 , ALL Ford bodies, were made by Ford and Lincoln. The caption on page 112 indicates that the 1939 Sedan Delivery bodies were made by Briggs. Other information in the same book, and others, indicate that 35,36,37,and 38 Sedan Delivery bodies were also built by Briggs. The caption on page 114 indicates that 1940 Sedan Delivery bodies were body by Ford. The change in who was to build the body of the Sedan Delivery after 1939, may have something to do with Deluxe models only, after 1939. Briggs had used mostly Standard model bodies, but when Ford took over, they used a new, clean slate, thus their switch to Deluxe. Interesting enough, the V8 60 was only available in one Deluxe model in 1940 - the Sedan Delivery.
08-31-2017, 01:29 PM | #37 | |
No V8 1940 convertibles were built by Ford. However, a number of them did get built with the 60HP engine. I was never able to find out why but did find proof that a number were built. And of course a few (111) were built with the Mercury engine.
08-31-2017, 01:50 PM | #38 |
Well, that statement will probably get the attention of a few. I'll cook-up a batch of popcorn. DD
08-31-2017, 02:28 PM | #39 | |
For the less informed... Ford did not build a "standard" in 1940. Rather, they built a "Ford V8" model. By 1940 Ford insisted that the dealers / salesmen no longer referred to their lower cost model as a 'standard" as it simply sounded "cheap". Instead, they were to be properly referred to as the "Ford V8". By the way Coopman, I am glad you are able to make popcorn. I understand you live all too close to the catastrophe unfolding in and around the Houston area. Stay safe please...
08-31-2017, 02:53 PM | #40 |
Thanks Kube......we managed to keep the popcorn dry during the last six days or so. We just got word that Mickey D's is open across the lake for a couple of hours as limited supplies last. Momma is off on a Golden Arches run as we haven't had Mickey Burgers in well over a week. Everything has been closed except for a VERY few gas stations since Friday. With the flooding, it's probably going to be very slow getting businesses re-supplied to operate. DD
