Old 04-06-2020, 05:35 PM   #1
STAN WHITE
Default Kelsey Hayes Wire Wheels/39 Lincoln Drums
I am a little confused seems to be happening a lot lately. As far as I know if you run 35 Wire Wheels or Kelsey Hayes Wire Wheels . And you are using 40 thru 48 Hydralic brakes including Lincoln brakes. A spacer ring is required to match the earlier drums and Spindel tabs that are on the 32/35 Brakes. I am using new Reproduction 39 Lincoln Brakes. They came with Plates like Spacers . These do not solve my problem as I still back to a flat surface with or without the plates. These plates do have a raised rib on the I.D. is that supposed to solve the problem? Stan
STAN WHITE is offline   Reply With Quote
Old 04-06-2020, 07:19 PM   #2
TJ
TJ's Avatar
Default Re: Kelsey Hayes Wire Wheels/39 Lincoln Drums
Did you call the manufacturer of the drums? They should have an answer.
Old 04-06-2020, 08:26 PM   #3
PeterC
PeterC's Avatar
I run Kelsey Hayes Bent Spoke Wheels with original Lincoln backing plates, 1935 Spindles and Brake Drums - so NO spacers needed front or rear for me.
PeterC is offline   Reply With Quote
Old 04-06-2020, 09:40 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by PeterC View Post
I run Kelsey Hayes Bent Spoke Wheels with original Lincoln backing plates, 1935 Spindles and Brake Drums - so NO spacers needed front or rear.
Peter.... That car is as pretty on the bottom as it is on top! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-07-2020, 07:03 AM   #5
PeterC
PeterC's Avatar
Originally Posted by V8COOPMAN View Post
Peter....Didn't you mean "NO" spacers needed? DD
PS: That car is as pretty on the bottom as it is on top!
Thanks - corrected to No spacers!
