Old 12-08-2018, 08:59 PM   #1
jdpalmer
jdpalmer's Avatar
Default Bottom rumble seat
Recent purchased 29 sportster and the bottom seat move forward. I see two hole in metal under seat but this seat has just the sprinted on bottom. Should there have been a plywood board and the seats fastened to it soppegs could be attached to go in the metal holes to secure the seat
Jimmy Palmer
jdpalmer is offline   Reply With Quote
Old 12-08-2018, 08:59 PM   #2
jdpalmer
jdpalmer's Avatar
Default Re: Bottom rumble seat
That’s springs on bottom
Jimmy Palmer
Old 12-08-2018, 10:55 PM   #3
midgetracer
midgetracer's Avatar
The springs should have a narrow loop that fits through the holes in the support to keep the spring from moving forward.
midgetracer is offline   Reply With Quote
Old 12-09-2018, 07:20 PM   #4
jdpalmer
jdpalmer's Avatar
What's it look like
Jimmy Palmer
Old 12-09-2018, 07:44 PM   #5
midgetracer
just a little u shaped piece that is about 1.5 inches long and is made of spring material. I would take a picture, but both of mine are put away for the winter.
Old 12-10-2018, 06:10 AM   #6
springerpete
springerpete's Avatar
If you look at the bottom of the spring of the seat cushion you will see two metal loops that project out from the spring. These will fit into the holes you are asking about. Set the cushion in place upright and you'll see the projections match with the holes.
springerpete is offline   Reply With Quote
