08-21-2015, 01:20 AM | #1 |
A' & B' carbs; I need a part!
Since I know the difference between an A & B carb, I am not asking for an opinion, just some direction. I have a B' carb and it needs a rebuild; the new rebuild kits do not have the needle & seat included... Macs' Brattons & Snyders no longer carry the B' needle & seat, even though they were listed in their catalogs. I have not been able to locate anyone with the correct B' type needle & seat can anyone tell me the differences between the size or length of an A' versus a B' - could an A' be installed but somehow shimmed or changed to fit in a B' carb? Does anyone have any suggestions.... Thanks
08-21-2015, 05:41 AM | #2 |
Re: A' & B' carbs; I need a part!
Bert's list a B carb kit on page 51 of their current catalog. You might contact them to see if it contains the part you need.
08-21-2015, 07:51 AM | #3 |
Try Renner's Corner, rennerscorner.com, (734) 428-8424, for the parts.
Charlie Stephens |
08-21-2015, 07:56 AM | #4 |
Hey Steve I have 2 model B carbs that I am bringing to the swapmeet for the model a ford museum
Wanted Roadster Pick up thank you COLOR] |
08-21-2015, 10:05 AM | #5 |
http://www.rennerscorner.com/carburetor.html
Would this work? RC-9590-32 Description: ZENITH CARBURETOR REBUILD KIT Comments: 19 pieces with flowed jets ( no float valve ) Application: 1932-34 4-cyl |
08-21-2015, 02:14 PM | #6 |
1929 (early) Model A Special Coupe - restored to original 1964 Buick Wildcat convertible |
08-21-2015, 03:23 PM | #7 | |
Berts in Denver have the float valve for the B carb, A-9564-b, however it is the ball type valve, I will never use another one due to sticking shut, call David at Renners Corner for a steel pin original type float valve, he has some used valves.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
08-22-2015, 08:42 AM | #8 |
Thanks for the info. That means I would have to enlarge the orifice to 2.7mm or .106 in.
I am curious about the leaking ball type valve. Have others had issues?
08-22-2015, 10:15 AM | #9 | |
