01-28-2013, 12:10 PM | #1 |
Holley 8HA carb leak
After getting the little V8-60 purring with a Holley 8HA 1-barrel carb it has started leaking at the top of the float bowl gasket. I overhauled the carb and know how to do it.
I'm thinking the float may be set too high. It uses a rebuilt, stock fuel pump. I think the surfaces are flat but want a starting point before I take it down again. Thanks. |
01-28-2013, 12:15 PM | #2 |
Re: Holley 8HA carb leak
The fuel is not supposed to be that high. fix the float or needle valve and it will stop leaking .
(From there at least.) Mart. |
01-28-2013, 02:28 PM | #3 | |
01-28-2013, 04:06 PM | #4 |
Did you make that adapter for that carb on a 60? That's pretty cool. Walt
01-28-2013, 06:48 PM | #5 |
It's a cast bronze adaptor. The engine is powering a Hobart welder and I guess it needed steady power instead of a lot of it.
01-29-2013, 05:22 AM | #6 |
I dig coal, which provides motivation for EVs. |
