11-09-2012, 09:44 PM | #1 |
Restoring 31 running boards
I am about to get started restoring a set of 31 running boards. They have a large amount of the original rubber coating on them. Do you think I will be able to get that off a commercial sand blaster or will I need to use a chemical stripper on it? Thanks.
DMAFC |
11-09-2012, 10:24 PM | #2 |
Registered User
Re: Restoring 31 running boards
i dont think a sandblaster will work
i would try electrolysis if you have a tank i found it caused the rubber to break down rapidly |
11-09-2012, 11:17 PM | #3 |
Sandblasters do very poorly on rubber and thick paint.
How about using a sharp wood chisel to peel it off? |
11-09-2012, 11:19 PM | #4 |
gas works good to soften it and then peel it out
John |
11-09-2012, 11:41 PM | #5 |
A heated scraper or wide chisel works well on hard old rubber. Heat it with a torch, doesn't have to be real hot and use good welders gloves and it should be like a knife through butter.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
11-10-2012, 12:20 AM | #6 |
http://www.harborfreight.com/multifu...amp-68861.html
