03-12-2022, 11:56 AM | #1 |
Rear engine/transmission mount.
I am dropping a 60hp flathead v8 into a 28 A chassis. What do I need to support the back of the engine and transmission? Should I get the cross member from a 32 or newer or is there one that fits the A?
Sent from my iPhone using Tapatalk |
03-12-2022, 12:56 PM | #2 |
Re: Rear engine/transmission mount.
Not an expert here, but make sure it is strong enough to prevent what I have seen way back in the day, namely the feared "torque twist"
03-12-2022, 01:04 PM | #3 |
Not too worried a out the frame with a 60hp.
Sent from my SM-T550 using Tapatalk |
03-13-2022, 09:44 AM | #4 |
The two most common rear engine cross member mods are the 1932 K-member and the F1 pickup cross member. Most of these were for full size V8 engine installations. The little V8-60 is similar but definitely smaller and also has different front mounts. The model A engine, at 200 cubic inches, has more potential for horse power than the little V8. At 138 cubic inches, it developed 60-HP at 3500 rpm. The torque was only 94 Ft/Lbs at 2500 rpm. Torque and horse power are very low at low rpm. It all came in at high rpm. This made them perfect for the midget class but not worth a crap for a regular automobile. They had to use very low rear axle gearing and special transmissions to make them work at all.
Modern testing on the model A engine gave 83 Ft/Lbs at 2250 rpm on stock compression engine. Horse power was lower than what Henry claimed at 35.6. With modifications, some pretty simple, the engine starts to wake up. Here is an interesting link. http://www.rarecarrelics.com/tests-t...ord-engine.php The V8-60 was raced back in the day but it was mostly in midget race cars and they are pretty small. It didn't take much HP to get the midgets to go fast. They did well enough but they were in a class all their own. Parts for the 60 are getting harder to find every year. Last edited by rotorwrench; 03-13-2022 at 10:12 AM. |
03-13-2022, 09:55 AM | #5 |
A stock V8-60 developed less torque (97 lbs-ft) than the Model "A" 4-cylinder engine (128 lbs-ft).
Bob Bidonde |
03-13-2022, 10:32 AM | #6 | |
I would stick with a stock A and do some head upgrades etc if you want a little more, or go the 85 or 100 route. That defiantly has its complexities. Wouldn’t even be a choice of power plants even if free. Larry |
03-15-2022, 07:35 AM | #7 |
Thanks for all the encouragement about the 60. We will see. I am not looking for a speed demon, I want something to tool around my lake country in Minn. 7 miles to town, 3 miles to my shop 30mph with a slow start will be just fine
03-15-2022, 10:19 AM | #8 |
What transmission are you planning to use w/that 60?
03-16-2022, 07:14 AM | #9 |
The standard 3 speed that came with the 60hp
03-16-2022, 10:41 AM | #10 |
Old Yankee Speed Co makes a kit
