Old 08-06-2019, 03:15 PM   #1
DC 69
Default CCPU Rear Window
Were the original rear windows on a '27, '28, and '29 CCPU the same size or different dimensions? If not, what are their respective sizes?
Thanks for the education in advance.
DC 69 is offline   Reply With Quote
Old 08-06-2019, 07:04 PM   #2
Joe K
Joe K's Avatar
Default Re: CCPU Rear Window
All the same. See http://jmodela.coffeecup.com/glass/glass_lg.jpg upper RH corner.
The drawing does not differentiate between the "high window" version of the CCPU or the "centered window" version.
And keep in mind the "AA" designation was how Ford in this drawing referred to any commercial vehicles. The same cabs were used both on the "A" and the "AA" version.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 08-07-2019, 09:41 AM   #3
Neil Wilson
Neil Wilson's Avatar
And keep in mind the "AA" designation was how Ford in this drawing referred to any commercial vehicles. The same cabs were used both on the "A" and the "AA" version. Joe K
Actually, the 82-A closed cab began as an AA cab only. The linked service bulletin is May 1928 (when the 82-A was only an AA cab). The rear window glass dimensions is for the high rear window cab. The glass corners need to be changed slightly for the lower rear window cab. I have not see glass dimensions for the lower rear window cab.
The 82-A became available on the A chassis June 4, 1928 (see A-1 RGJS).
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
