05-06-2023, 09:17 AM | #21 | |
Re: Clam shell help
05-06-2023, 09:27 AM | #22 |
Re: Clam shell help
Me too! It can't be working with that gap in it.
05-06-2023, 09:40 AM | #23 |
Re: Clam shell help
Is the inner cover in place ? It fits over the u- joint and the bell end of the torque tube mates to the rear of it then the cover with the seal holds it all in place. The gasket set will be listed as a U-joint gasket set.
05-06-2023, 09:41 AM | #24 |
Re: Clam shell help
Hey guys,
Yep, I imagine it would probably eventually leak even with that void is located at 12 o’clock when bolted back up. My plan is to remove that piece of rubber and replace it with a smaller diameter piece beingvery careful there are no voids at the ends. If this fails, and I still have noise, I’ll install the felt from 3rd gen. Richard |
05-06-2023, 10:43 AM | #25 |
Re: Clam shell help
Sorry, the noise and the seal are unrelated unless as a remotely possible cause, your engine steady rods aren't there or are loose.
05-06-2023, 11:27 AM | #26 |
Re: Clam shell help
05-06-2023, 01:33 PM | #27 |
Re: Clam shell help
Ken, looking at the Vanpelt diagram, I believe all of the parts are there. How would I identify a Lincoln U joint?
Richard |
05-06-2023, 02:49 PM | #28 |
Re: Clam shell help
The Lincoln joint has caps with needle bearings and the Ford joint has bushings and you can see the ends of the cross. The only way to see it would be to slide the rear axle back far enough to remove the inner cap .
05-06-2023, 03:14 PM | #29 |
Re: Clam shell help
Ken, here’s what I’m looking at.
Richard |
05-06-2023, 03:37 PM | #30 |
Re: Clam shell help
Well, you definitely have a big problem that absolutely needs to be solved before you can drive this car - anywhere. A major component of the whole torque-tube system is missing. I'm not sure the actual name, but I call it the "ball or pivot cup". The only way to fix it is to pull the rear-end, or pull the engine and transmission and install it on the back of the transmission.
Torque-Tube-Pivot-Cup.jpg This is the "ball side" that the torque tube runs up against and pivots on. Whomever put this together either didn't know about this piece, or forgot it . . . or both. You're completely missing the necessary part, and that is what is screwing with your transmission (the torque-tube is hitting the u-joint). It is a wonder you were able to drive the car at all. There are multiple ones on eBay at the moment - various prices: https://www.ebay.com/itm/125910290812 Another: https://www.ebay.com/itm/37419560779...Bk9SR6zJiaz-YQ |
05-06-2023, 03:44 PM | #31 |
Re: Clam shell help
Yep. That’s one of the Lincoln joints. Your problem is that you’re missing the inner cap. I’d replace that u- joint. The rear axle needs to be slid back to remove it and install the inner cap.
05-06-2023, 03:46 PM | #32 |
Re: Clam shell help
05-06-2023, 03:47 PM | #33 | |
Re: Clam shell help
05-06-2023, 03:51 PM | #34 |
Re: Clam shell help
Note, the rear transmission mount is first installed, then the U-joint is bolted to the transmission output shaft first, then the pivot cup is installed (with gaskets on both sides of it) - and it slides over the four protruding bolt ends on the back of the transmission mount.
Then you put the outer clam-shell piece onto the same 4-studs/bolts that you slid the pivot cup onto. The four nuts that hold the clamshell on will push it against the outer gaskets of the pivot cup and the torque-tube end will ride against it. You always lubricate the pivot cup with heavy grease before you pull the torque-tube against it. Without the pivot cup, the torque-tube has nothing to ride on and pivot against. Currently it is trying to move forward and is hitting the u-joint, which then causes your "clicking noises" and causes the transmission to not operate correctly. I'm quite surprised you were able to move the dang car at all! Whomever worked on your car (transmission/rear/torque-tube) - doesn't understand how this stuff all works - sorry to have to say that. Last edited by Bored&Stroked; 05-07-2023 at 09:15 PM. |
05-06-2023, 04:04 PM | #35 |
Re: Clam shell help
You've got to be kidding! Please post the name of the firm of idiots who left out that cup so that no one else is tempted to use them.
05-06-2023, 07:40 PM | #36 |
Re: Clam shell help
Hard to imagine all the Hell the owner has been through (time, money, aggravation, etc) - all because of a missing $20 part.
05-06-2023, 08:23 PM | #37 |
Re: Clam shell help
Wow.
B&S, I think I have the pivot cup. See the first two pics in post #1. I’m missing the outer clamshell piece that covers the pivot cup? Do you have a picture of the outer clamshell cover? BTW, here is a picture of the clamshell area before I took it apart. Richard Last edited by Ricosan; 05-06-2023 at 08:35 PM. Reason: Add photo |
05-06-2023, 09:12 PM | #38 |
Re: Clam shell help
You have the outer clamshell piece because it is integral with your torque-tube. The later ones were split into 2 pieces, while the earlier V8's - at least 32 - 34 had a one-piece version that was slid onto the torque-tube during the manufacturing process. It really wasn't a clamshell - it was a retaining ring that held the front of the torque tube against the pivot cup. So, you're not missing it.
From the looks of your picture, it appears you MIGHT have the pivot cup (at least originally). I believe I see a shiny metal piece against the rear transmission mount. Did you misplace it . . . or have somebody work on the car who might have misplaced or lost it? In the picture you posted before - it was obviously not there. |
05-06-2023, 09:27 PM | #39 |
Re: Clam shell help
05-06-2023, 10:33 PM | #40 |
Re: Clam shell help
Your two photos in #1 show the outer cup as only the outer cup has the formed channel at the back to hold the seal. The inner cup does not have that formed channel. Further, the cup-shaped portion of the outer cup is larger in size than the cup-shaped portion of the inner cup as the former fits over the latter.
