11-15-2021, 10:49 AM | #21 |
Re: Coolant flow diagram
Good morning boys,
Well lots of good info passed along overnight, thank you. I think you have answered all of my questions and I have all the info needed to proceed with the cooling system and EFI stuff. Agreed, the EFI probably isn't as critical as I think, I am just trying to do things best I can for my first TBI conversion. Glad I asked about the heater core as I wasn't thinking about air pockets. Someone has put the shut-off valve on the water pump so I will move that to the head. And as the engine now has a chrome alternator on it there is no need for an Ammeter and I have a second gauge set so I was planning on putting a second temp gauge in the cluster so I can monitor both heads at the same time without a toggle switch. A couple of pictures of the engine. Cheers https://www.dropbox.com/s/s315y6q3tg..._1025.JPG?dl=0 https://www.dropbox.com/s/ris3g2ng1s..._1026.JPG?dl=0
1949 Ford F-47 with a '51 8BA Flatty, GM TBI fuel injection system, and a grey shop cat, Spot. |
11-15-2021, 11:23 AM | #22 |
Kilohertz:
What is the purpose of the two resistors shown in the wire leading to the coil? |
11-15-2021, 11:43 AM | #23 |
11-15-2021, 01:39 PM | #24 |
Good grief! When I donned my spectacles, I could see "Resistor Required".
I was wondering as I had never seen that type of resistor set up before. Thanks for your input. |
11-15-2021, 02:11 PM | #25 |
As I am electronics tech, it's what I had in my supplies to use the coil for my temporary startup to test the engine and newly machined Chevy distributor, truck will be 12 volts when it's done. Ultimately I'll be putting a GM TBI setup on this and the coil will be replaced.
Cheers
11-15-2021, 03:25 PM | #26 |
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
11-15-2021, 03:30 PM | #27 |
"A couple of pictures of the engine."
11-16-2021, 12:19 AM | #28 | |
And yes, glass fuses make great temp vacuum line plugs...sometimes permanent. Cheers PS Pete, thanks for inserting the pictures...I don't have the patience to resize all of my pics to conform to the sites size limits.
1949 Ford F-47 with a '51 8BA Flatty, GM TBI fuel injection system, and a grey shop cat, Spot. Last edited by Kilohertz; 11-16-2021 at 12:26 AM. |
11-16-2021, 01:17 AM | #29 |
What's the story on the dipstick & tube there on the right side rear of the engine?
11-16-2021, 01:26 AM | #30 | |
It's been an amazingly fun project to date, currently working on the GM TBI system and built an adapter plate today for the TBI to Fenton 4 bbl manifold ... fun fun fun ... cheers
1949 Ford F-47 with a '51 8BA Flatty, GM TBI fuel injection system, and a grey shop cat, Spot. Last edited by Kilohertz; 11-16-2021 at 01:39 AM. |
11-16-2021, 01:36 AM | #31 |
Oh!....I should have known that....Silly me....
11-16-2021, 09:31 AM | #32 |
A lot of Canadian Heads are aluminum but this likely doesn't affect what is needed for this question.
Flatheads with their dual cooling systems do pose a bit of a problem for an ECU that needs only one coolant temp probe for the whole engine. The only place that the coolant mixes together is in the top of the radiator tank. Installing a probe there would require installation of a bung in there but it could be done. If the engine has a problem on one bank only then the system will eventually be overheated as a whole due to radiator circulation. One side heats up faster but the whole system suffers from that. |
