05-22-2016, 03:13 PM | #21 |
Re: Speedometer / speedometer drive gear
Mitch; thank you. I am going to put the rear wheels on jack stands and see what things look like, when the drive shaft turns.
Thank You;
Brian French; 1930 Briggs Town Sedan |
05-23-2016, 08:26 AM | #22 |
Not knowing the inner workings of a speedometer, is it possible that the speedometer freezes, or locks up inside, causing the drive gear to stop and break a tooth?
Should I buy a rebuilt speedometer, and try again? With the rear wheels on jack stands, and a wheel chock under one of the rear wheels, and me wife turning the other wheel, I still do not see any axial movement of ecentric motion from the spiral gear on the drive shaft. Any suggestions, please. Thank You;
05-23-2016, 08:28 AM | #23 |
A hanging speedo head would easily take out the cable first
05-23-2016, 10:10 AM | #24 |
Mitch; I did have a cable break at the drive gear end. It broke the thin aluminum housing, that captures the nut to hold it to the drive gear housing. I was thinking something in the road hit it, but maybe this is leading back to the speedometer head.
The last couple of housings I put on, I used multiple gaskets, thinking I didn't have enough clearance. I think that's why it looks like the drive shaft gear was riding on top of the speedometer drive gear. I have a rebuilt speedometer and will try this with a new drive gear and 1) gasket. Thank You Very a Much;
05-23-2016, 02:43 PM | #25 |
The broken cable housing end that connects to the drive gear housing (turtle).
05-23-2016, 03:51 PM | #26 |
I still think you have to much movement in the driveshaft bearing... Unfortunately it is a lot of work to replace... If it was a speedo head issue it would just twist and break the inner cable and not do all the damage that's happening to yours. Last edited by Mitch//pa; 05-24-2016 at 04:56 AM. |
05-25-2016, 10:55 AM | #27 |
Photo looking up.
05-25-2016, 02:31 PM | #28 |
Should the drive shaft, spiral drive gear slide towards the transmission, about 1/4" ?
That's the only movement I can get. I put a jack with a wood dowel on it, and pressed up on the gear. I used a magnetic base indicator, and saw about 0.003 movement, when I jacked up, and applied pressure. Thank You. I am perplexed.
05-25-2016, 03:09 PM | #29 |
Yes that is normal movement
05-28-2016, 08:01 AM | #30 |
I found this picture in my archive photograph's, and I am sure it came from a Ford Barn member, however I cannot find the post.
My question is, is the wire ring shown, supposed to lock into the drive shaft, or does it slide easyley? Thank You;
05-28-2016, 08:18 AM | #31 |
The wire ring should snap into a groove in the driveshaft.
05-28-2016, 08:36 AM | #32 |
Tom; thank you. It seems like mine is not snapped in, and the existing ring seams to be sprung.
Is safety wire an alternative? I was thinking that I could do that from the speedometer gear drive hole?? Thank You;
05-28-2016, 11:04 AM | #33 | |
"Over the years of taking rear axle assemblies apart I have noticed that there is a space, maybe 1\8" between the front of the drive gear and the circular snap ring. I have come to the conclusion that the snap ring is not there to position the drive gear as the driven gear assembly will do that when it is installed. I suspect Henry put it there so that the rear axle assembly could be transported down the assembly line hung up-side-down and the snap ring kept the roller bearing, thrust washer and drive gear from falling out." Bob |
05-28-2016, 11:14 AM | #34 |
Bob; that's awesome, thank you very much
Thank You;
